  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Twin PT52 Precision Turbo Engine Turbos will provide the Boost. Each Turbo is capable of making 600HP or 1000CFM of Air. Together the combination is good for at least 1200HP and/or 2000CFM of Air. The Turbos were selected to have a small nozzle diameter as well as a .85 AR Ratio. To allow these Turbos to spool up quickly in order to reduce the sensation of Turbo Lag.
:drooling:
mike if you read this before you go.
there is an arcade on murray street if you are walking down from pier street carpark
go past baskin and robbins
and then there is an asian grocery store
go past that and then next to it is an arcade. there is a shop in there called Aspec
go talk to franky and he will get you all the globes etc you need, he knows what goes in etc
no worries Mr Riceroni
peace
nah - soarer turbos use the same engines as the chasers. though with less beefy cams I think.
the old 1jz. little brother to the 2jz.
later model soarers came in a 2.5L tt, 3L6 n/a and the 4L v8s. now theyre purely v8s I think. but I have seen a twin turboed version of the new one in a video of some tuning shop in japland. forget which one....
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
