you'll be happy to know Joe - plastic smell has been replaced by fuel smell :rofl:
Mike .... yes aircon on = sluggish car .... that swhy most of us dont even have aircon. secondly yes hot weather is not the best for turbo cars .... all our cars a lot slower in this weather .... obviously turbo cars work a lot better on a cold air intake that an phucking hot one!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oooh .... zorst shopping with aidwin :rofl: ... good fun!
TJ - even tho im a heartless bitch on the outside i still on the inside feel sorry for some of my actions cos im really a nice person ... you know that ...just some individuals push the boundaries of my patience.
Mikey ..... we arent all as scary in person as we are on net ... you'll probably find once we meet you we'll lay off a bit
i know ur cool niz otherwise i wouldnt talk to you. Simple
now all i need to do is just Paul out of the picture
:ghost:
hahaha she wont... lol she will eat you alive in the motorplex!!! as TJ said it will be SMACK DOWN :Bang: and she will :flamed: you ... lol
BTW watch out for crazy dodgie korean guy... he dont hold back
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
