  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul how about a give you my jap coin which is like 1 yen i think sounds like a good deal 2 me.
nah but 4 real how much is the membership fee? have u work out one yet? do we get anything like card or keyring or something like that?
I can be the club noob :newbie:
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
