  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Riaz- just make it over 220HP at wheels.and ur project will be sweet
Yeah Riaz 220 at the wheels should give you a pretty sweet power to weight and gives some of us Skylines owners more than a bit of a shcok from the lights!!!
ok all the fustration is out now *clam blue ocean* on with the report that doesnt end .... yes it goes on n on my friend .... some stupid blonde bitch started typing it not knowing what it was .... but wait until she's typing it forever just because .....
Mike your odometer not working isnt something I know how to fix etc. it just proves the theory that no KM's are to be trusted on a jap car, which is what i told you anyways. and now the frgging thing stops working, its all too dodge.
maybe the previous owners C-red might be able to help fix it.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
