Cecam ...... because we can ... and no i dont have any work to do :P i move around jobs cos im a temp so i just run up the net bill and leave before it comes in :P
I was employeed as a temp... 3 weeks work at the time... that was four years ago, I guess I should really get my contract updated...
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah November i finished up at the Dept Industry n Resources ..... i was employeed originally for 2 weeks ..... 10 months later they finally end my contract ..... unfortunately when i went to work for them the were merging with a different department .... i got to stay while people that had been there 15 years got the boot :P
Yeah well you just need to make yourself needed and it solves that problem usually, but kills off promotion options in a larger firm if your not replacable... something like that anyways...being a small company it was never an option for me regardless. I looked late last year for another job but theres stuff all around at the moment... well for the same pay anyways.
yeah i know about being to valuable in your position and therefore going nowhere ..... thats the reason why ive left permanent employment ... although cant say im going anywhere much doin gwhat im doing but im getting paid well and im getting the experience to go where i want to infuture .... anyway home time ... nice talking to you :P
Aidwin, If you read back, Ant has fixed the issue with your clutch, and it's only running 11psi, so we're going to put it back up to 14psi, and it should be making the sort of horsepower we expected to get from it at the dyno day but didn't:D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
