  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by docile
nah, all ready to put down a deposit on an autoworx car (although a car i had a drive of at CRed was ok too) but sumthing said no.....
Found out a couple of guys at work (who i've known for ages, just never knew they had good cars) have rexes that do easy high 11's (with nos) and low 12's (without).
So after having a drive in their cars, i've decided on a rex....
Hmmm , thinks
* what is he doing on this forum then ? *
Cheers
Ken
Originally posted by PACEY
Yerr rex are good, i think it all comes down to personal preference really. My mate had an ex targa wrx running 25 psi, that was the first really fast car i drove and fuuuuuk that thing moved, still the fastest car ive been in so far.
Ex targa rex ?
Must be fairly new cos they only let them into to Targa last year.
Cheers
Ken
Guest
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
