Originally posted by Nizmo
But i didnt change it so the stocker wont be in my possession.
Nah what the hell lets go for something rice while i have to change it :P Been recommended a recirculative one.
Only serious post for the night.
Niz you need one that recircs most of the air back into the intake system or it disrupts the airflow meter. Gives a false reading which causes stalling , black smoke and bad idle , especially after you have just fanged it.
Cheers
mechi Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well i know Ken reads it cover to cover :bahaha:
well someone has to proof read it for errors.
sides , you are on twice a day anyway young lady so what's your excuse:D :shake:
Cheers
ken
Cheers
mechi Ken
Who me?! fang my car? never!! hehe ok well yes - I have got and done all the above I wouldve just got them to put one on today because it ended up costing me a bit less than i thought but by the time i rang at 4 to find all this out it was a little too late.
If i buy one will Ken fit it *batts eyelids*
Originally posted by angel
Just like to put P platters and women who give you dirty looks in their place. And guys who think you have no idea what your car is.
ahhh P platers . We all were one once but geez that drive like idiots.:P
Suppose we were just as bad ( surely not ).
Cheers
Ken
Cheers
ken
Well my excuse well um err because i work in the international trade and investment office we do a lot for japan so im just doing my little bit of research into their exports :P yes thats it :P
ohh yes and what Troy said as well haha
aww what happened to the * battered eyelids *. I thought they would be rather tasty. Hehehe
I'm sure we could come to some arrangement
* checks wifes diary *.
Nahh , seriously , Paul and myself ( so we can chaperone each other ) should be able to help.
I mean if he can change his oil , then how hard can a bov be ?
Cheers
Ken
Guest
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
