wondering how long the hdd will last with the usually stiff suspension in most skylines.
Most hard drives are pretty tough now a days. I've dropped a few and they still running fine. If you mount the hard drive sideways as opposed to flat, you'll lengthen the life of the hard drive too.
  • Replies 50
Yeah they are fairly tough, but I dont expect mine to last much more than a year though... HDD's definitely dont like to be moving when they're spinning! The price of laptop hard drives is cheap now anyway.. You can get a 60GB for $110!
The only way to counter this is with a flash hard drive, but they cost an arm, a leg, and your 1st born child's soul unfortunately.
Like, try $117,887 (yes, ONE HUNDRED AND ELEVEN THOUSAND!) for a Memtech 98GB Flash SATA Hard Drive! ;) Pretty silly when you remember that 4GB USB memory sticks are only $160 now! :(
That shouldnt be an issue!
Go to Mp3car.com and search "tweaks".. Find guides to disable services and crap the pc doesnt need etc... This will shave a lot of time off your boot up from cold.
I havent optimised mine yet, and its running at about 20 sec's boot resuming from Hibernate! By the time I get into the car, and wait for the LCD screen to slide out and up, the thing is pretty much booted! I think I have to look at a black screen for only 2-3 seconds! Youre using Hibernate and not shutting it down every time are you?
The Opus Power supply takes care of the hibernating and shutting down. I think its like when ignition is turned off - goto hibernate - then 15mins after shutdown. Alls I'm saying is that if windows boots quick (20 secs) from a standard hard drive. imagine how fast it'd run from flash memory.
Got some pics of your install Prim?
Ahh ok.. yeah booting from flash would be very quick!
I havent got pics at the moment.. I'll post some up tonight if I get a chance. The only thing you can see is the lilliput 7" motorised touchscreen in the dash. It's difficult to even see the laptop as it's mounted under the drivers seat on a docking station so i can remove it easily.
Which front end are you running?
Yeah thats what you would expect... The read rate and transfer rate are two different things. The transfer rate of USB2 is up to 480MBit/s... Where an average HDD is only about 120Mbit/s...
The READ rate (how quickly the drive can pick up data off the platter) on a HDD is usually between 30 and 70mbit/s...
So the read rate on the USB flash could be faster or slower... Im not too sure. But the Bus/transfer rate on USB2 flash disks is certainly higher. Whether or not thats the actual rate that data is read off the flash chips is another kettle of fish!
^^ This isnt gospel... it's just what I understand from the small amount of research i've done! :unsure:
I guess the best way to test it would be to copy a 100MB file from a USB2 > HDD, and then do the same file from a HDD > HDD. If the HDD>HDD test is faster, then you've got your answer!
There is a huge amount of issues regarding booting from USB2 disks though
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
