hey guys
im new to skyline world and recently bought a 99 R34.
it has a tv screen with lots of jap writing. tv is not working, radio is not working, and when i play dvd's i can see the pic when im driving,( just sound).
i think some safety shit.
anybody knows anything about this problems
tanx guys
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/
IM pissed, i bought a 1998 R34 GTT, and i got the three guages in middle console, ive seen the GTR which has the pop up screen, but i have seen other GTT with a similar screen, which is tv and sat nav and all this...
this isnt a question, its just me being annoyed
sorry
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1595851
sorry
The GT-R screen -- its known as the Multi Function Display (MFD) -- isn't "pop up": its fixed. The screen you might be referring too in the GTT is the naviation option that some GT-Ts have.
DAMSXC: If by radio "not working" you mean you can't tune it to Australian stations, is because you need a frequency converter. As for the screen not displaying DVDs, does it work with the handbrake on?
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596130
yea it works when handbrake's on or when im stop and my foot is on the brake.
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596885
Then its working correctly. You are not meant to be able to view DVDs whilst the car is in motion. As already mentioned, you can get around that by fooling the DVD/TV into thinking the handbrake is always on.
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596888
  • 2 years later...
Hi Guys,
I got a 99 R34 GT-T, and the in-dash display won't pop up. The upper lid can be lifted by hand, and I can see (probably) the LCD panel etc, but they won't lift. My mate could read Japanese (Kanji, I think) and I can figure out what the buttons say. However, some ppl reckon that it's the pully mechanism thats not working. but, since I cant see anything happening when I press the buttons (Open/Close etc), I am wondering whether it could be electrical? Any help is appriciated. Also, since I live in SE suburbs, Victoria, someone mentioned that there is a guy in Rowille who has fixed one of these...
Thanks
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-3919167
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
