hey guys
im new to skyline world and recently bought a 99 R34.
it has a tv screen with lots of jap writing. tv is not working, radio is not working, and when i play dvd's i can see the pic when im driving,( just sound).
i think some safety shit.
anybody knows anything about this problems
tanx guys
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/
IM pissed, i bought a 1998 R34 GTT, and i got the three guages in middle console, ive seen the GTR which has the pop up screen, but i have seen other GTT with a similar screen, which is tv and sat nav and all this...
this isnt a question, its just me being annoyed
sorry
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1595851
sorry
The GT-R screen -- its known as the Multi Function Display (MFD) -- isn't "pop up": its fixed. The screen you might be referring too in the GTT is the naviation option that some GT-Ts have.
DAMSXC: If by radio "not working" you mean you can't tune it to Australian stations, is because you need a frequency converter. As for the screen not displaying DVDs, does it work with the handbrake on?
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596130
yea it works when handbrake's on or when im stop and my foot is on the brake.
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596885
Then its working correctly. You are not meant to be able to view DVDs whilst the car is in motion. As already mentioned, you can get around that by fooling the DVD/TV into thinking the handbrake is always on.
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-1596888
  • 2 years later...
Hi Guys,
I got a 99 R34 GT-T, and the in-dash display won't pop up. The upper lid can be lifted by hand, and I can see (probably) the LCD panel etc, but they won't lift. My mate could read Japanese (Kanji, I think) and I can figure out what the buttons say. However, some ppl reckon that it's the pully mechanism thats not working. but, since I cant see anything happening when I press the buttons (Open/Close etc), I am wondering whether it could be electrical? Any help is appriciated. Also, since I live in SE suburbs, Victoria, someone mentioned that there is a guy in Rowille who has fixed one of these...
Thanks
https://www.sau.com.au/forums/topic/88394-r34-tv-screen/#findComment-3919167
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
