If you want to see my in car video of me doing my 9.4 sec pass
at 160 mph,I then went on to set a new record and win the event.
Go to the link below and download the second video down
Hope you like it
http://www.totb.co.uk/movies/
Keith
Edited by keith cowie
https://www.sau.com.au/forums/topic/88447-my-in-car-vid-93s-160-mph-pass/
Congratulations Keith!
Been following your efforts for a long time on GTROC UK :D
edit: I just watched the vid, and I think you shut it down early!!!! :O  :P
Hi Merli
We were having fueling problems all day,we found that
it was a fault with 1 pump at high revs.
The EGT at the end of the runs were about 1000 degrees
this video was taken in the final and I was a good second in front
so I didn't see the point of risking my engine so yes I backed off early.
Keith
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
