A good read this thread...
Whats everyone's thoughts on igntion timing and AFR's?
I had my cars tune touched up on friday and it feels like a dog now, but makes more power peak.
It previously was tuned to around 11 to 1 AFR's midrange and around 11.5 up top, and my tuner leaned it off pretty much everywhere as he thought it was costing power. In doing this, he had to reduce timing (obviously) otherwise it was detonating
So on the dyno, it seemed ok, it picked up about 10rwkw peak
On the road, the car is a dog
The lean AFR's in the midrange and decreased timing has knocked the punch that it used to have right out of it
Before, it would light up 2nd no probs, and feel quite punchy, now it feels like it bogs down and doesn't even chirp the wheels
It will be getting re-tuned, but how do others prefer there cars
I know I would rather it a bit richer and more timing than lean with no timing!
  • Replies 70
yeah, i quite like the more timing more fuel approach too. but it obviously needs to be approached senisbly as more fuel is only worthwhile to a point, as is more timing. but for sure to generalise i'd rather have a little more timing, and a richer mixture than less timing and leaner mixture.
Who'd you get it tuned by Chris32? I suggest you take it back and tell the tuner that the midrange needs more work. You paid for a better tune, not just neccesarily a better peak power figure..
Shaun tuned it at Boostworx
my fault, as i'd been playing with the fuel map and made it quite rich! So i asked for fuel to be taken out, and thats what I got! It did make more peak power everywhere in 4th, but in 1st, 2nd and 3rd it felt flat because fuel was taken out in some of the load area's
Already spoken to Shaun about it, going to get it back in on thursday and fix it up. In all fairness it was done in a rush on friday night after work, it was just supposed to be a tidy up! but had to redo allot of it!
Funny, as I just got of the phone with Shaun
He tuned to the knock light this time, which is why he took a fair bit of timing out of it - hence why its feels flat now! Last time he turned it of, as it was faulty
I thought i'd made some progress in that area with the lag timing etc, and turned it back on. I think it did help in regards to acutal knock, but the light/sensor is still playing up! Bastard! Well, booked in for thursday arvo, will be tuned ignoring the dodgy sensor and see where it ends up
Ignoring the knock light from now on, will eventually get to the bottom of that problem. What about yours, is it still playing up?
Will be going a bit richer again and a bit more timing to keep the response up. Nothing worse than a laggy feeling car with not enough top end due to smallish turbo!
Edited by Chris32
losing good mid range power and gaining a very pissweak 10rwkw means 2\10's of f**kall to me.
You aren't at 6500 - 7000 rpm all the time are you?
Mid range is where you are the most I say... Tune the power back there...
Hmmmm if nissan couldn't do knock feedback timing above 4000rpm what makes you think that a PFC can distingish between engine noise and a detonation event? Your tuner should no what real knock is by listening to the engine with or without a chassis ear not to mention NOx levels going through the roof. I know it might sound like an amazing thing but knock levels will be different for different cars/engines all this comparing knock levels is BS.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
