  • Replies 73
will r33 rb26 coil pack fit into R33gtst rb25?
if yes i will take it.. thx..
email me to [email protected] or pm reply thx
Jon, I believe in fact that if your car is the early R33 GTS-T then they will fit.
Nick
  • 3 weeks later...
hahaha sorry...um that black plastic tubing that joins the two pipes together. Should have been more specific.
Oh and I want the piping too......along with that tubing thing.
ah f**k it...here is a pic....
Actually Nick, before I committ to the sale, just wanna ask if these can be polished up to look all shiny like the one in the pic
Are they an aftermarket item or are they stock items given the buffing treatment ?
Edited by shonen
Thomas, yes people polish the standard pipes in the pic there.
I have the main section with the Twin Turbo written on it, the rubber joiner you circled and the rear section that bolts to the back turbo
Nick
Nick
SOLD......
my last exam is on the 25th.....ill arrange with you to get it after that..
  • 3 months later...
  • 8 months later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
