Thanks buddy....
I got a set of semi slicks last night so ill be heating those babies up!!!
Any tips??
I dont know, i havent ran mine yet those RA1's.
Give it plenty of revs, ease out the clutch and then slam those gears. I wanna see a 12.
Id love to see a 12... i know the car is capable, it will just be the driver that isnt!!!
Didnt have a very good night at all....
Ran a 13.8 best time and had about 12 runs!!
As stupid as it sounds i must have been backing off before the end because mid track i was really moving but by the end the numbers just didnt work out...
I ran another R33 a few times, only mods he had were exhaust, cooler, safc and .8 bar boost... pulling 190rwkw!
It was good to compare, here was one of our runs:
Me:
60ft 2.375
660ft? 85.41
Et 13.813
Mph 105.38
Him:
60 Ft 2.436
660ft? 78.35
Et 14.157
MPH 105.55
As you can see I had a better 660 ft? or 1000ft time not sure which one it was but he had a better ET.... it doesnt make sence...
That was a bad run for me, i had a best of 2.1 60ft and 660 or 1000 ft of about 87mph but the Et was never under 13.8 sec??
Any suggestions? I think im going to have to go down again soon and this time keep the power down after the time posts and beyond!
The car seemed drive fine and pull really hard... mid track it was really moving compared to other R33's....
Any help is appreciated guys..
Cheers
Edited by silva33
It was my first time and by the time i realised i may be backing off short it started to rain... so i guess i wont know till i run again which will be soon!!! but im positive i could see the time flash before i backed off...
Then again i didnt keep an eye on the boost guage so who knows, it may have been a boost problem!
Anyway, ill have to wait and see on the next Calder trip!
Edited by silva33
With 105mph, it doesnt seem like you were backing off. 105 is good for very low 13s or high 12s...
60ft time seems to be your problem considering you were using slicks. Practice your launches :D
105 isnt bad but i was running another R33 GTST with stuff all mods and he was getting higher ET's... the figures dont add up as he only has 190rwkw and i have 244 rwkw!! surely my ET would blow him away even with a worse 60ft time... i also had a better 60ft time and got a 13.8 where he go a 14.1 and his MPH was still better!
Mid track my Speed way quite a bit higher than his and by the end he was just faster than me... so there is either something wrong with the car or i was backing off becasue i was redlining every gear....
I would have expected a mid 12 with a good 60ft and at least a 110mph pass...
It was my first time and was great fun so im going to head down soon to get me that 12 and learn how to launch her!
Edited by silva33
Definately you where backing off with 85mph half track, my best was 89mph half track and i finished with 113mph. I've done it before as it doesnt really show you where the finish line is as there are 3 sets of lights.
Might head down with you if you wait a few weeks and im planning on a real low 12 or even possible 11
yeah somethings not right seeing as my gfs soarer with nothing but a catback and pod ran a 13.8 and my R32 with stock cooler, stock engine and just 14psi, ecu tune and exhaust ran a flat 14... all with crappy street tyres.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
