Hey mate; if you end up getting that wing off... can you do me a really big favour? Could you measure up all the holes for me (both boot lid and bottom of spoiler) as well as the diameter for the screw/s?
I'm planning a little DIY thing (making new spoiler stands for stock spoiler) so I need that information :D
Cheers mate!
EDIT:
Also, I'm going to link your site up tonight, cool? :)
Edited by satanic
Are you talking about the coupe wing?...cause i've taken that out and it was easy...Yeh..ill measure it up for you when i get around to it....lol im scared i might lose the nuts for the stand..cause it can fall inbetween the boot framme..which is a bitch to get out.Only way to get it out is to remove the whole boot :D
ill take some pics while im at it too
hahaha Thanks Satanic...
ill make a links page tooo...and of corse you be on the list :)
Edited by E_Lu-SHuN
thats a pic of a coupe.... :P
wasnt it supposed to be a sedan with a coupe spoiler>?
Sorry dude, wrong link...here's the link to the sedan with a coupe wing...looks out of proportion...
http://www.tradingpost.com.au/Photos/W64569067043.jpg
  • 1 year later...
It's held on with that double sided foam and It's a nightmare to get off. It just needs lots of muscle power and patience. Have you popped the 2 white plastic lugs (1 per support leg) that fit between each legs set of bolts yet???
sorry to bring this up again. i need to remove my coupe spoiler.
so how do you pop the 2 white plastic lugs? do you pull it downwards?
could those who have succeeded taking their spoiler off shed some light?
cheers
haha, funny..I was just about to start a thread about removing my spoiler..on a sedan though...so E-lushun if you found out could you please enlighten us! I want to know if removing the factory spoiler leaves any permanent marks on ur bootlid??
Cheers :)
did you get my PM? i took mine off - fishing line is your friend :)
Yeah mine is a little different to your Nismo version. Im not worrying about the adhevise tape stuff yet. Those plastic lugs are the trouble, I could only get one finger through the hole so no way to pop them out. Dont want to pull the whole spoiler out and break the lugs either.
  • 2 years later...
Hugely old thread, and I don't care - I can't find anything else on this topic for us R34 sedan owners.
I learn't a few things in my efforts tonight, which may help someone in future:
i) An R34 coupe wing is not a direct bolt-on to an R34 sedan - the rear bolt hole is in a slightly different location, but otherwise fits quite well
ii) The R34 sedan wings are a bitch to get off, with a tonne of double-sided tape, and some evil lugs at the back which you have to try and undo (which in my case snapped on one side because it just refused to come out)
On the positive side, I'm very happy with the results - slightly more aggressive without being stupidly big. I also still think it suits the lines of the car.
( After on the left, Before on the right )
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
