SAU CRUISE - Saturday February 1st.
Right *puts on moderator hat* Erin, got sit in the corner, Damqik go sit in a different corner...
Damqik, you said sorry in a most sincere way and seem more than genuine, I applaud you.
Erin, I know you, have met you and I have said worse things to many people over the UHF's. Pull your head in and stop being stubborn or no Squizzmobile luvin' for you.
He didn't mean it, and he's sorry - aren't you Damqik? - see he's nodding and all teary now kiss and make up before I have to bust out some kung fu and let the poo off the stick and into the lake with the squid!
  • Replies 121
Garage SPANK:  Longer harder faster
Damnit!! Why do all the good ones have to be so far away? I mean if I want to get some decent spanking action on I'll have to drive 7 hours..... hmmm might be worth it though. So, when is that garage open Sqiuzz?
Grrrrrr *Austin Powers voice* I can feel my body getting hot already.
Whoops did I say that in public? I mean I'll be there Slip, unless I'm up North on a "Business Trip" heheh.
Good Old Macca's ICE CREAM......
Well what ever the seems may be i'm hope that this will be a big cruise as this is the social event.... and remember we all like looking at the Eye Candy, AND NO I'm NOT TALKING about the guys/gals, i'm talking about the Skylines. Whether it be an R30,R31,R32,R33,R34 :D
See You All There
:burnout:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
