Just Jap is pleased to offer this unbeatable deal on our new type 1 and type 2 intercooler kits.
These are a complete bolt on kit with a high quality polished 600 x 300 x 76mm intercooler, chrome plated or polished piping, silicon joiners, stainless hose clamps and brackets required for mounting the intercooler on your vehicle.
Dont be stung by cheap inferior kits that lack the quality you expect - All piping is of an extremely high standard with beaded ends to prevent your pipework from coming off.
No nasty welding or rough finishes here!
Each kit includes a 1 year warranty and Australia wide delivery is also available
We have a number of these intercooler kits in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PICTURES OF THE TYPE 1 KITS - (CHROME PLATED PIPEWORK)
TYPE 1 COMPLETE KIT FOR S13 SILVIA/180SX (SR20) - $449
TYPE 1 COMPLETE KIT FOR S14 & S15 SILVIA - $449
TYPE 1 COMPLETE KIT FOR SKYLINE R33 GTS-T - $449
TYPE 1 COMPLETE KIT FOR SKYLINE R34 GTT - $449
TYPE 1 COMPLETE KIT FOR SUBARU WRX GC8 - $449
PICTURES OF THE TYPE 2 KITS
(POLISHED PIPEWORK & TRUST STYLE CORE)
TYPE 2 COMPLETE KIT FOR S13 SILVIA/180SX (SR20) - $499
TYPE 2 COMPLETE KIT FOR SKYLINE R32 GTS-T - $499
TYPE 2 COMPLETE KIT FOR SKYLINE R33 GTS-T - $499
TYPE 2 COMPLETE KIT FOR SKYLINE R34 GTT - $499
So how do take advantage of this limited offer?
The answer is simple!
Visit www.justjap.com/forumcoolerkitspecial.htm and purchase your intercooler online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
They are selling very fast so be quick
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 51
shouldnt u be able to do the polished kit (type 2) for $574 since thats your price for the same intercooler with the blue piping.
No, sorry mate.
The blue piping is the old piping for the type 1 kits which has now been replaced by chrome piping.
The type 2 kit uses polished piping and a Trust style core and thus is a little more expensive.
would your universal intercooler fit a piping kit which i have purchased from Just SR for a R33 skyline series 2
600 x 300 x 76-3 inch
Hi mate, thanks for your enquiry.
Assuming the piping kit is correct then the answer is yes.
Cheers,
Steve
Whats the difference between type one and type 2? I can see theslight shape difference but what else is there? Does Type 2 cool more effciently?
The type 2 uses a Trust style core and polished piping, and therefore is slightly dearer than the type 1.
Performance wise you would find minimal performance difference between the two, if any.
Cheers,
Steve
do i need to cut holes anywhere to fit the piping thru on a r33?
Hi Dean, as with the majority of front mount intercooler kits for skylines, you will need a 3 inch hole cut in the thin section of your inner guard, on the drivers side under the washer bottle.
Cheers,
Steve
Hi Dezz, the Type 2 kit uses polished piping and a slightly different Trust style core, where the Type 1 kit uses chrome plated piping and a standard type bar and plate core
Cheers,
Steve
i want to buy a type 2 kit for my 32...r they in stock??
Hi mate, yes we have them in stock :blink:
Cheers,
Steve
I will be wanting a R33 S1 GTST kit soon...
Will you still have them around christmas?
how much is shipping to 2257 NSW?
Also where are you located?
We always keep these kits in stock - We are one of Australias largest intercooler suppliers.
Total would be $590 delivered for a Type 1 kit.
We are located in Kirrawee, Sydney (Near Sutherland)
Cheers,
Steve
What about shipped to erskine park near penrith?
Or is it not far for there...
Did doodz come and pick it up? If yes i will ask him
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
