Hi,
I'm going to appear for a driving test and can anyone give me tips? I mean what they look for etc. I heard that you're not suppose to look to either side before you come to a complete stop at stop signs.
And that you're suppose to check your rearview mirrors every 10 secs?
Little stuff like that.
https://www.sau.com.au/forums/topic/89144-driving-test/
Have you had any lessons at all?
If your goin for the one off test, just ask em before you leave..
they will tell you.
As long as you dont ask them how to drive, you should be right
Be very observative. everytime you pull out from somewhere ie. Turn a corner... then check you rear mirror.. just keep looking, and make it obvious your looking.
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1609675
Dont put your car into neutral when coming to a set of traffic lights, use your handbreak even if your on the SLIGHTEST hill and there is any!! chance of rolling back. (even if you think you can handle it... do it anyway just to be safe)
use push pull method of steering (you might already do this?) mirror check... ment to be every 5 seconds rear view? (check in the learning to drive book, they give you this when you get your L's...)
Basically just drive with care, as you would no speeding etc, stop at stop signs.. all the basics, you should be fine.
If you dont have the learn to drive book, i suggest you go get it... this is what they mark you off.. from memory there is 24 compitencies (sp) and the 23rd compitencie is the actual test.... Give this ago? and get one of your mates to mark it off as if he was your instructor... for things like reverse parking you get two attempts etc.
Dayne
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1609744
don't leave your hand on the gear stick after changing gears...make sure you put it back on the steering wheel asap..
maybe the most important thing is to be confident - but if you've been driving that long i'm sure you'll be ok there.... i just think you have to act like you belong on the road cos if you look petrified and scared of everything you they'll think you're not really ready to be out there on your own :huh:
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1611472
I once got shot down for merging "too quickly" (If that makes sense)
As in when passing through a 2 lane merge, don't instantly plant yourself in the middle of the newly formed single lane, but instead just continue to hang off to the side of the lane that you're coming from, just in case there's someone in your blind spot that you might end up crunching into if you put yourself in middle of the merge straight away
(I don't think I've made any sense at all)
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1611548
and with automatic transmission, do you put your gear selector in N if you are at at stop for a long period of time? And what's the point if you are to use your handbrake if you are in D? Do you just keep your foot planted on the brake pedal?
And what's the penalty for driving a manual car with an "automatic" license. My car's an automatic and I"ll have to use it to appear for the test.
Thanks for all the tips. They're helping me alot. I would just drive to the middle when I see the "FORM ONE LANE". So you're suppose to just follow you gutter until the lane becomes narrow enough for one only.
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1613349
as far as i know it changes to a manual after a certain period of time (a year?) anyway...I have no idea of the penalty though.
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1614379
I got my manual licence first go, and i've only owned a manual car for a year since i got it (5 years ago). first car was auto and current car is auto. i don't think you'll care if you get an auto licence after a year you can drive whatever
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1621229
I dont know what the deal is down here, but the majority of people I know on the Gold Coast just go for their licences in a driving instructor's car.. thus you kill two birds with one stone: You know the car is going to be reliable and fairly nice to use, and it's a manual.
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1621537
In NSW I cannot tell you how many people fail because they fail to stop at the STOP sign when they pull out of the RTA drive way. Automatic fail there! Beware.
Also you'd be surprised how many ppl offer bribes just to get their P's! A friends uncle works for the RTA and it ranges from cash sums to ppl (girls AND guys) offering some "back seat action", it's beyond stupid. Learning to drive isn't THAT hard! I'm sure if you can spread your legs (or in the guys case, bend over) then you can work a steering wheel and 2 pedals.
https://www.sau.com.au/forums/topic/89144-driving-test/#findComment-1621954
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
