whilst removing the cam gear cover to check out my cam gears.. i noticed the little pins inside the cas, and the pin on the camshaft that line each other up are broken..
only the one on the camshaft seems to be broken, but without knowing where to line it up with, i beleive its affecting the CAS, and my car wont start... it turns over, and makes a few small attempts at starting.. but it wont start properly..
any ideas? if the CAS was attached to the cam shaft, but not lined up correctly, would the car still start? and how would i go about fixing the pin?
cheers.
https://www.sau.com.au/forums/topic/89361-cas-pin/
Been there, done that.
If you look very carefully at the camshaft side, you can see which half of the hole the key was attached to. You then need to visualise the CAS key matching over the imaginary cam key.
The CAS is also driven by meshing teeth, and it ends up that there is really only one position that the CAS can go back on that will permit the engine to start.
https://www.sau.com.au/forums/topic/89361-cas-pin/#findComment-1612868
ya, i saw it had the teeth mesh... i can kinda see where the pin snapped off when ive got the cam cover off, and the bracket that the cas atttaches too off..
but when ive put it back on, and the cover on, its hard to see where it lines up...
cheers anyway, ill give it ago in better light on the weekend.
https://www.sau.com.au/forums/topic/89361-cas-pin/#findComment-1612870
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
