Guys,
I am changing the diff and gearbox oil shortly.
Is there a sort of oil that i should use for the diff and gearbox?
Gearbox: oil?
Diff: oil?
Engine: oil?
What my previous car (VL with SubZero build RB25DET), I used Mobil 1 for the engine. What oil do people recommend to use with a standard engine, not using any oil at all...
Thanks.
https://www.sau.com.au/forums/topic/89831-enginegearboxdiff-oils/
redline mt-90 for gearbox
then maybe motul or mobil1 for engine
(actually i use pennzoil 10w40 for engine oil. works fine for me... make sure your engine oil is quality and correct weight, but i wouldn't go spending $100 for an oil change with redline stuff. just make sure you change every 4000-5000kms)
probably redline for the diff aswell. though i wouldn't be too worried about diff oil with stock viscous lsd (just make sure the diff oil is for LSD, as the non-lsd diff oils are different)
i use motul 8100 in my engine (i'd use chrono if it was in any higher state of tune) but i change it so regularly, i dont think its too much of an issue. i pay $50odd for a sump full of 8100. chrono is more like $120ish from memory.
i used redline oils in my diffs and gearbox and i will NEVER use anything else. that stuff is liquid gold.
d
redline lightweight shockproof in my box. can't remember specifically which fluids went into the diffs.
d
yeah lightweight shockproof in the box but use MT90 in the diff. I was having a chat with the guy at rare spares and i asked him why this would be and he was going on about the mt90 has an oil treatment additive in it so the diff doesnt clunk and make alot of noise, you can user lightweght shockpoof and you can by the redline oil conditioner to add in so it works better. so i just went the mt90 thats what redline recommend anyway.
I use
Engine: Motul 4100 Turbolight 10w40
Diff: Redline Lightweight Shockproof
Gearbox: Redline Lightweight Shockproof
yea thats what i was told too and decided to go with the lightweight i havent had any clunking though.
ps the diff and gearbox are bitches to do if you are just using the bottles they come in :(
Gearbox redline light weight shock proof
diff redline mt90
gtr tranfers DONT USE REDLINE you most use the matic d nissan oil if you want it to last (this came from a head more knowledgable than myself who had rebuilt a shit load of transfers)
engine mobile 1 is good so is the redline products
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
