How come all the dynos differ in price so much?
All I want is to set the boost using the dyno, adjust the timing and then to give me a readout.
I've had prices ranging from $50 to $130 odd (per hour).
Where is a good one to go to?
Also, do I have to use a 4WD dyno or can I put the car in RWD mode? It won't affect anything if I use RWD mode will it?
Cheers.
https://www.sau.com.au/forums/topic/9010-dyno-prices/
  • Replies 84
I guess like with all different quality of services you pay more in some and lessin others.... I use PSI performances dyno and so do MANY other high performance tuners.
I heard a rumour on the weekend and i dunno how true it is so i aint gunna stand by it but i did here that with the 32 GTR's instead of pulling out fuse or wire apparently when you 1st start ignition it's 4wd then if you turn it off then turn back on again it goes into RWD if this is true?? could it work for the 32 GTS4
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-133834
I will always tend to use the same person over and over, aslong as they do the right thing by me then I will support there business.
To do a power-run should only cost about $70 per hour, it requires some playing around and minor adjustments, but if your not after tuning then it shouldn't cost you too much.
I use Steve at SST, he build race cars and has a number of clients with fast cars including 11sec Skylines, Evos and has a 8sec SR20DET powered rail.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-133968
I use Ivan at APA (ex Speedworks), he's recently got his dyno and it has some serious amount of accuracy and repeatability. I get full lambda graph printouts etc, AFR... all that crap ;)
And no wheelspin, you bolt the car up to the hubs!
http://www.power-analysis.com.au/
I think the dyno is out at JRT in bentley at the moment for anyone who wants to enquire. I think the price is around the $60-70 mark. I've been getting mates rates so im not sure exactly :)
Red17
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-134159
Seriously, If you go to a place to tune your car and they don't know how to disable the 4WD then get the hell out, they obviously don't know what they are doing. Anyone charging $130 per hour for a power-run is a rip off, as you can see there are many good dyno's around which we all will be more than happy to go back to. the important thing is once you find one you like then stick to it, that way you can tell the affects any mods have to you power in relation to that one dyno.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-134487
Originally posted by RB20LagWagon
If you want it done cheap, go to barry's he is a good bloke too, i mean its only to set boost you aint getting it tuned to be a 10 second monster.
If you can ever get him to answer the phone.
Seriously , I know he is a good operator and I knew him when he worked for Darryl Penley ( ATS )and that was probably before most of you guys were alive but is that any way to run a business ?
Cheers
Ken
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-134628
Gtrken and Strichnine,
I understand where your coming from, but when the other tuning shops don't know what to do with a car they send it to Barrie, everyone knows he is the best, it's just that you have to deal with all the other crap. He works by himself, and doesn't answer phones etc, so if you want it done in a hurry then your better off elsewhere, if you need something fixed which no-one else can do then he's your man.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9010-dyno-prices/#findComment-134702
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
