The ACL's are a good bearing, the race series bearings have a hardened steel backing which keeps them well located in the housings even when they have had some heat. They are fairly soft which is a good thing if there is anything floating around in the oil as it can embed in the bearing. They are not hard on the crank either, not really an issue with an RB as the crank is pretty hard to start with.
I still prefer King bearings, the material is better, only one layer of bearing material about .015" thick on a super hard backing, the alecular material has a melting point almost 3 times higher than the babit on a regular trimetal bearing so there is less chance of delamination even under extreme loads and heat.
Nissan bearings are made by NDC and are a trimetal bearing, I have seen these delaminate when they cop some detonation. I haven't used Nismo bearings, I'm still pretty sure that they are a trimetal bearing, one benefit I suppose is you can buy them graded to adjust clearances but then if the bearing housings are not on size they should be remachined anyway. I haven't had problems getting spot on clearances with the king bearings, all the bearings in a set are guaranteed to be within .0001" tolerance so there is no chance of tolerances stacking up and changing clearances. The other benefit of Kings is the price, they're cheap as dirt compared to Nismo bearings as they are a standard replacement bearing.
The HX bearings run an extra .001" clearance over the H series.
Yeah..thanks for that. I guess ACL reccomend the extra clearance for the 26 because they typically make a bit more power than the RB25.
When they say 1 thou extra clearance, any idea what the clearance will come out at with a brand new crank?
Cheers.
ok cool ,
so who sells King Bearings and what kind of cost we looking at for a set of bigs and mains.
on another matter the nissan specs clearances are pretty damn good
ie there factory spec 0-3 for main tunnel and main journals is only
+/- 0.0005" for the 4 spec sizes or a mass producted engine thats pretty impressive and no wounder people dont have many problems with tolerances even with out using the 6 grades of nissan bearing.
pete
It has had the alloy plugs that seal off the oil galleries in the crank removed and been tapped to take screw in grub screws to seal the galleries. You need to remove the old plugs when you rebuild the engine to clean the crank properly.
It's a good thing, whoever did your engine did it properly, it doesn't affect anything else.
Warning!!! ACL PRODUCT WARNING. Were supplied new race series forged ACL pistons, rings and bearings for an rb30/25 hybrid. Engine built buy a reputable engine builder and run in by ex Perkins engineering mechanic/tuner. Rattled from new and pulled down at 2000Klms to discover massive wear on the drive side of the bore. Piston to bore clearances measured at 7 tho and within spec. ACL denied refund/replacement and rolled out these excuses in this order. 1. Detonation (cleared after hardness test) 2. Foreign substance in bore (brand new engine run in on dyno with standard air box and new filter) Cleared after excuse number three. 3. Over boosting causing rings to break down and cause abrasion on bore. (Stat decs signed by engine tuners engine stating run in boost set to max of 14psi). ACL now tell me that there FORGED race series pistons are only rated for 10PSI. This engine has a comp of 8.2:1. Standard engine runs 9:1 with cast factory pistons at around 9psi...do the math. Currently taking legal action. Any questions regarding this "race designed product" PLEASE contact me @ [email protected] .This is not a rant, but an opportunity for other people to learn from experience.
7 thou clearance thats f**king hugh what is there recomend clearance on install out of interest
  • 5 years later...
hi there i am in the middle of building a rb30/26 and wanting to use acl race series bearings but they are on back order i have the option of using th hx bearing which give 001" extra oil clearance are there any pro and cons to using these or should i wait for the standard one which will be weeks
ACL are in Liquidation, so stocks are pretty much Zero on things, the extra clearance will help if you want to rev it fairly hard or want to run big power, (if its a 26/30 than I assume you want a fair whack of grunt)
  • 1 month later...
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
