  • Replies 58
Posted Images
Do you have a fuel pressure reg?
How do stock injectors induce the 'lag'? Would be good to know what duty cycle your hitting - you don't have a h/c?
252rwkw sounds pretty close to what i made on stock turbos. Do you have adjustable cam gears?
No i dont have a regulator or hand controller unfortunately.. the inducing lag bit didn't come out quite right. My tuner said basically if there could be more fuel put in down low it'd spool it up quicker, but the stock injectors are pretty close to their limit and pushing them closer would be living dangerously. So, if I did the fuelling upgrades im sure we could get it spooling quicker, how much quicker I got no idea.
Yeh got HKS cam gears..don't think they were adjusted with latest tune for new turbo's.
I can't see how you can be at 100% duty cycle down low? that doesn't seem right. i can see them being at 100% at 8000rpm, but not at 3000 to 4000? I could be wrong though.
Exactly my thoughts. I don't know much but i would assume at 4000rpm, they only have to fire half as much as they would at 8000rpm. From what i have seen, injectors usually max out up the top of the rev range.
We need someone more knowledgable to answer :angry:
Fuel pressure reg should help get a little more out of the injectors. Only a couple of hundred bucks.
the gearbox can handle more power than that. just don't abuse the gearbox and don't put a solid centre clutch in it, i know from expereince :O
i know that gtr gear can handle more power....but jono think that his gear box is stuff...cant run....
Jerry: any idea what the difference would be between your setup and GTR032? Just tune or something else?
Well , i have a 34 engine , almost new , tune of course is different well under 12-1 at 11.5-1 , i wont run 12's on a stock engine .
I dont have cam gears or dump pipes but the 34's have s/steel dumps not cast and i have 550 injectors , the other thing mine will only make 240 awkw .
I'm not after big power in my setup , i just want a quick street car not big dyno numbers .
I did 11.8 @ 118 mph a couple of weeks ago with a bit left in her still , i'm happy the way she goes as i have plenty response , almost like a stocker and 34's are more responsive that 33's and 32's (if all 3 are stockers ) .
Actualy if i had steel wheel turbos i wouldn't bother with the gtss's , thats the reason i tried to buy an NUR M-SPEC , maybe next time !
Gtss's are not cheap but in my opinion ideal for a stock engine but stock injectors would be right on the limit , thats why i went for the Nismo 550's ( again not cheap , you can get sard much cheaper ).
Can injectors have anything to do with lag like GTR032 mentioned earlier in this thread?
Why are 34's more responsive than 33's and 32's stock?
No they shouldn't have ,as they supply all the fuel needed, i dont know if the cams are the same in the 3 cars , so that maybe one reason , different turbos is another and who knows they may run more timing as well as better dump pipes . Ports and valves i think are the same but i never had a 34 head off the car so i cant say for sure , i'm only going on what others have told me . I know from experiance they run more boost .
Are you going the gtss road Andrew ?
All you need is the turbos ,dumps, power f/c, ebc and 550 injectors , as long as you have a good donk ( do a compression and a leakdown test to confirm ) and you will have a much quicker car and almost as responsive as it is now .
GTR032: how is your car going anyway?
I had the pleasure of being a passenger in it for 1.5hrs the other night and I must say that it drives very well. It has better response/power under 3000rpm than my R33 GTS-t did with the stock turbo B)
Yep turbos and pfc are on thier way.
Car's going pretty good. No dramas since new tune :P
Just got to fix up an ongoing tailshaft type vibration. After that will take it down to WSID to get a time.
...Deadset? Thats pretty damn cool. I sure as hell dont want to go for a ride in Fernis car when its finished...aint enough Prozac getting around
there there Troy... Just put on that GTR bonnet etc, and get three gauges for the centre console and sit in the driveway making car noises. then you will feel like a GTR owner. :)
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
