Originally posted by Pva_Glue
I guess... but then again
reacently I found out there is such car called "Sileighty"
Silvia front + 108sx rear
cheers
Joe
there also is a one via s13 back 180sx front
fifteen eighty also- s15 front 180sx back
fourteen eightly also- s14 front 180sx back
a 4wd silvia would b a really good idea but its all about the $$$
https://www.sau.com.au/forums/topic/9070-4wd-silvia/#findComment-135339
Originally posted by NuGGeT
a gtr ute?!?!
R32 Drift Ute Video
mate bought a sil80 in 98 or so, he bought it because he liked the looks of it and didnt know it was a sil80.. we rock up to see his car and our jaws dropped. never ever seen one in perth before then, now their everywhere.
how many REAL ones did Nissan make, if they did?
Shaun
https://www.sau.com.au/forums/topic/9070-4wd-silvia/#findComment-135457
Apparently nissan only made about 80 genuine ones...i think.
I believe the answer lies in the information page about the Sileighty in Gran Tursmo 1 & 2.
Drift guys did it alot because the 180SX front end is worth a fortune, pop up headlights and all.
Nearly bought a black Onevia... was a sweet looking car. :P
Red17
https://www.sau.com.au/forums/topic/9070-4wd-silvia/#findComment-135471
Red17
Nissan sold 400 genuine Sileightys, they had harder suspension and a few strut braces, bigger wheels etc ... basically driftable in stock trim.
I just put the silvia front end on my car on the weekend.. so, i have a replica Sileighty now, i love it. ;) ;)
https://www.sau.com.au/forums/topic/9070-4wd-silvia/#findComment-135480
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
