  • Replies 79
Year: 1999
Colour: Pearl White
KMs: 95000
Mods: Nismo panel filter, Blitz FMIC, CES split dump/front pipe, Fujitsubo cat back, Nismo 480cc injectors, R34 GTR fuel pump, R34 GTR fuel regulator, Chipped ECU, GCG highflow turbo, AVC-R, full respray, rebuilt transmission to handle 300rwkw.
RwKw: [email protected] bar
Now has blown engine as latest mod.
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635608
Year: 1998 Series 1
Colour: Nismo White
KMs: ~40,000km
Mods: (performance only)
K&N Panel Filter
Trust PEII Cat-Back Exhaust
Manual Boost Controller @ 10psi
Front Mount Intercooler
SAFCII D1 Limited Edition
Iridium Spark Plugs
Voltage Stabilizer Kit
FMIC and Radiator Cooling Panel
SAU STICKER - 20rwkw alone :P
RwKw: 196.4rwkw @ 10psi
Dyno Graph (if any):
There is one, can't be bothered looking for it (it's on the forum somwhere).
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635668
Year: May 1998
Colour:Black Pearl (GV1)
KMs:120thou'
Mods:
Nismo 300km cluster
Nismo replacemet gauges for boost/volt/oil temp
Apexi avc-R
Apexi Safc II
Apexi ECV
Garret GT30 with external 38 mm TurboSmart ultragate
Full 3inch exhaust with 5Zigen muffler
Z32 afm
Splitfire Coilpacks
oil catch can atmo
bosch 040 fuel pump
brake cyclinder stopper
HKS oil cooler relocation kit
HKS air filter
HKS Hiper D coilovers
Greddy FMIC
camber arms
aftermarket rear sway bar
Carbon Ztune style bonnet
Carbon eyelids
18" BBS LM wheels
RwKw:
220 kw at 0.8 bar
Pics (if any)
Edited by E_Lu-SHuN
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635712
Year: 1998 Series 1
Colour: Black GV1
KMs: 114,000
Mods:
RwKw: was 350rwhp on RB25 engine
Pics (if any)
well done ian thats a crazy gtt! awesome website too very useful as a gtt tunning guide!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1643912
Year: May 1998
KMs:120thou'
Mods:
Nismo 300km cluster
Apexi avc-R
Apexi Safc II
Apexi ECV
Z32 afm
Splitfire Coilpacks
oil catch can atmo
bosch 040 fuel pump
HKS air filter
Greddy FMIC
camber arms
Carbon eyelids
18" BBS LM wheels
RwKw:
220 kw at 0.8 bar
Pics (if any)
mmmmm sedan goodness....
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644038
Year: 1998 coupe
Colour:black pearl
KMs: 63500
Mods: Blitz FMIC, 3"exhaust with split dump, Airfilter and nismo clear indicators front and side.
i need to put a tunable ecu on it becasue std ecu hitting rich retard mode, but i have an auto Any Ideas???
No pics as yet dont have a digital camera.
have no idea how much rwkw, but for a near stock car it flies!! I love It!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644196
Year: 1998
Colour: White (not the pearly one)
KMs: (87000kms)
Mods: 3" Turbo Back Exhaust with Split Dump Pipe, Cold air box with pod filter.
RwKw: not much more than stock
Dyno Graph (if any): none
Pics (if any): see signature link
Cheers!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644557
Year: 1998
Colour: Sonic (or Athlete, cant remember) Silver
Kms: about 46,000
Mods: 300x600x75 FMIC, Apexi Pod Filter, Greddy Turbo Timer.
RWKW: I guess around stock.
Dyno: none
Pics: in my sig.
Edited by RyanN
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644948
See what I mean about confusing :O
There is a NISMO kit and a seperate Nissan Motorsport kit which are 2 different kits. The Nissan Kit fitted to yours was available as an add-on when you bought your car (like a sunroof, colours etc). The NISMO kit wasn't, it had to be bought seperately.
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1645351
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
