So there i was walkin over from my parked car to northbridge, i hear tyres squeaaling, too long for a launch or an e-brake... then next thing i hear... Crash. LoL. Some asian (Most likely from china, as i was there when he was talkin to his friends and the police. I'm Singaporean, so i kinda can tell the difference.) did a 180 on a 2 lane road and crashed into 2 cars, 1 car moved backwards and hit the rear, so total of 3 cars damaged. So the cops were just round the corner, rushed over, and he tried to escape. DOH! LoL. Stupid ass knew better than to do this kinda shit over at northbridge. But at least he had some brains, and he stopped after a while. So if u thought parking ur car by the road is safer as u won't get badged, due to the high flow of traffic or coined. (well coined is higher as pple can just walk past and coin ya). Think again. LoL. Heaviest damage was done to a mitsubishi magna. The s15 had a personalised numberplate. ZBR ***. All letters. I hope he loses his liscense forever.
Cheers!
https://www.sau.com.au/forums/topic/91174-s15-crash-at-northbridge/
oh there's a note on the window, the police left a name card ?!@?! i don't know man, looked like a name card with the police logo on it. Well at least they know who the culprit is. I've gotten hit before at a carpark before, my whole fender had to be changed. Bloody pissy when it has to come out of ur own pocket.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
