Nah just saw it on there. Was considering putting a bid on it but decided I probably have too many cars as it is. Looked like a pretty easy repair
Yep , i wasn't going to bid on it either , but i was on there watching something else :blush: , if the damage is worse than it looks in the pics i'll probably just wreck it
Buy the rota p45 from Rota aus on facebook, $1099 including delivery for 18's
cheers for the heads up, just checked them out wanted to go 18x9.5 +12 & 18x12 +20
but i dont want to hack my front guards or go wide rear, so thinking i may have to go 9.5 +32 & 10 + 35 :glare:
as im thinking +12 all round would still need guard work even though mine are allready rolled
interesting, mines quite abit lower then yours though.
i failed before the fronts would be +25 not +32
they have.
18x9.5 +12, +25
18x10 +12, +35
18x12 +0 +20
so thinking ill need 9.5 +25 fronts & 10 +35 rears
this 33 has 9.5+12 all round and looks mint! but no specs on camber ect
Edited by Autumn33
so after working it out on the offset calulator & then getting the trusty ruler out, im thinking i should be able to just get away with the +12's with some more rolling/lipping & stretch
Edited by Autumn33
Not too much to update. Last monday I put a new water pump, idler bearing/new Bolt and tensioner bearing on the old girl along with a new gates timing belt.
Yesterday arvo I made up my rear wing/boot bracing. very light and holds my weight very easily. I have made up a ally plate that fits nice in the passengers side of the boot to mount the surge tank and pumps/pump mounts to so it goes in and out as one piece. will plaster the rising sun over the tank and plate to mtach the engine =)
I'm at a bit of a cross roads with weight atm. I've sorta came a bit of the way and not quite sure where to draw the line. The head unit and 2 door speakers are in question, door intrusion bars along with door glass, might trade it for lexan... I would love to gut the doors and power windows and just have lexan in bare doors but I also want to keep from the B pillars forward in tact. I really want a carbon boot lid and then mount it on pins/latches and do away with the big factory hinges but that will have to wait as the money needs to go on more important stuff ATM
Got a ally rear diffuser/air guide planned for the rear. will get that underway in the next few weeks. more to aid airflow than provide any sort of extra dwonforce as ATM air can get trapped in the rear bar/boot floor area.
cheers
OMG, so much porn in those pics. Heaps jelly of your aero. If I had it though I'd just go backwards over a curb with it :P
Swapping Glass for Lexan I think is time to draw the line, skyline glass isn't that heavy anyway! You're better off spending the $$ on petrol and Tyres :)
its hard Nowelly. I need a new rear screen anyways. And I have spoken to Burgz about getting 2 orders shipped together. should be able to get a rear screen and door screens (and quaters but prob wont use them) in lexan here for 600ish. I was quoted over 300 for an aftermarket rear glass screen.... the door glass is actually kinda heavy. I know the rear isnt.
A nice light motorsport battery is def on the cards later in the year after the important stuff is out of the way.
haha yeah really its not huge coin. not when your already up for a rear screen anyway. its usually about 700 but if we can get two kits at the same time should save a bit on postage, shipping 2 kits compared to one shouldnt make shit all difference so should come in around the 600- maybe 650 tops. I prob wouldnt of bothered if I didnt need any but since I need the rear, kinda a 'may aswell while i'm there' thing lol
looking good Jack
cheers
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
