  • Replies 181
Posted Images
man! They are bloody bright! trust me, u won't be needing the highbeam much! but R32 are h4's? are u 100% sure? Cause i've got some vague suspicion they arn't. Anyway, If u want bright, 6000k is 2800lm (roughly) 4700/5000 are 3200lm. If i remember 8000k is less than 2800lm. A standard output of a halogen is 1000lm if i remember correctly. A good example would be lookin at the bmw, merc and stuff. Check the links i posted, they have comparison charts.
Cheers!
Checked mine out - I am H4 (bugger!) & would be after 8000K (I guess) but the question I have is are they really bright on low beam as well?
HID's are the low beam, high beam stays as halogen :P
Cool! Set me up for 1 for sure! When do u estimate we'll order it?
Oh yeah, regarding the h4, as bankids said, it's a motor that retracts and extends for high beam and low beam. They are usually called bixenons... that's why h4's usually cost a little bit more. Wherelse for h1,h3 etc, they are single fillaments and they rely on another bulb for the highbeam, like the r33s
http://www.xenonvalot.com/newh4bixenon.html << for reference.
that's the thing confused me alot, coz in everywhere ppl said hid have lower power consumption. normally halogen is 55w but hid is 35w.
but while i installed the hid into my audi a4 burnt my fuse which was 10a, later i put a 15a into the fuse box and everything seems alright now..
my stock headlights were pretty good, but the HID's are excellent. :wub:
so much longer range, and ive got 8000k i think (it was diamond white whatever temperature i bought), looks like daylight! :)
Yo! Diamond White is usually 6000k. When it's quite blueish it's 8000k, then 10000k dark blueish and 12000k is purplish. Daytime white is 4700k to 5300k that's what normal OEM hids come with. But they are the otimal. usually rated at 3200lm. 6000k is 2800lms. But, 2800lm is way more than the standard of about 1000lm. :) hahaha. HID's for a price of $200 is bloody well worth it man.
what is the best possible headlight xenon conversion on the market? i want something very clear , and you can get blue lense also?
h7 or something?
please tell me, i need it for S15
Best possible? You'd be lookin at Hella Ballasts, and philips/osram bulb/globes. Will set u back by a cool 1k. But no one will be able to tell the difference untill u actually show them it's philips and hellas, cause the standard these days are so universal and common that you're looking only at reliability.
Heck, you can buy 5 sets of these for the same price! Nothing gets clearer than HIDs. The bluish tint is not the lense, if u're lookin at lenses, and they tell u it's hid, you're prolly gonna get ripped off cause they are halogen "xenon" convertion where they use relays to pump the wattage to 110W and u get brighter lights. Then they use a cover to cover the bulb to give it the bluish/whitish look. The real xenons are what is being sold on the forum. With a slight bluish tinge, but mostly white, it's 6000k. More bluish is 8000k but a little bit darker, there's a trade off, then it becomes bluish purple 10000k, then purple 12000k.
S15 uses projectors, so look for the projector headblubs, but these days there are universal ones. Rated as D2C. I know there are sellers whom sell the wrong kinda bulb so as to clear their stock. EG: my friend bought projector bulbs for his MR-S. Thou using Philips and Hellas, his car is relatively low, but when i was driving my rav4 back home, i still feel the glare when in front of him. Which got him fined in the end, he had to buy another set of globes for SGD$250 just to be right. LoL. Oh wells.
Come on dude, join this group buy. I'm pretty anxious to get a set here for my r33 so, need to meet the 10 pple quota =E . They are one of the best investment u can make for ur car, esp when driving in dark places, you can see, literally, EVERYTHING.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
