orly?
hrmmm i am getting a bit of a miss fire at idle and at high rpms (7.8k or so)......but ive been running the bcpr7es's for 4 months now and its been mint.
ngk doesnt seem to make a 8 in the bcprXes range, which is why im asking if anyone has some part numbers handy........
as for the iridiums im here in the USA, shipping wouldnt be worth it, thx for the offer tho.
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1657443
changing the plug heat range will highly unlikely fix your problem.
what ignition system do you run, what gaps?
unless your using a sustained output of 400hp for minutes on end, going to a 8 rating plug will more then likely just foul up quicker and cause more missing, because they aren't hot enough to burn the carbon deposits off.
is this a dedicated race car or street car your talking about?
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1658449
currently running std ignition system, but looking into upgrading it.
i suspect a faulty coil but since im running higher than stock boost (17psi on high boost) i thought it would be wise to step up to a cooler plug.
i usualy run .8mm gap but gapped the plugs down to .6mm to see if that would help with the car any, but it hasnt.
this is also a street car that sees 400whp on the weekends but is on low boost (14) for the rest of the week.
Edited by carl h
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1658486
you need to upgrade your ignition system.
but i wouldnt go to a 8 unless its a dedicated race car.
iether
bcpr7ey or s (y = vgrooved centre electrode)
bkr7ey or s
bke7eix (iridum)
pfr7a or b etc (platnum)
or in denso.
iq22 (best one.)
all the normal coper ones should be changed with your oil.
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1659509
Lets remember to that 400whp US isn't 400whp AUS its probly somewhere around 330w hp so around 250rwkw. Its not to excessive power wise considering their 93 octane fuel. Check your coil's dude. Your miss at idle is probably due to you plugs being gapped so low. If you need a 0.6mm gap its time for CDI.
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1660017
car makes about 288rwkw's on a dyno dynamics dyno.
as far as the coils being bad im sure thats the cause, but as far as a ignition system upgrade what do you guys sudgest?
supra guys here stateside swear by the hks twinpower, while ive heard that it does nothing, any good reccomendations on cdi systems?
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1660023
im not a huge fan of splitfire coils as i noticed no diferance with them.
a twin power would be the easiest option.
sort of half a cdi but withought all the mucking around withe signal conerters for a msd and leads with twinpost coils. etc
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1660597
yah, from what ive been told they arnt much better power wise than stockers.......
as for the twin power, im kinda hesitant on it, some say it works others say stay away, so im not sure what to do about that.
i did however get some NIB GM DIS coils of ebay for a dollar, and for me to sort leads would be about 40$, so doing an external coilsetup wouldnt be too terribly hard........and if i did that i could go ahead and grab a msd dis-4 box and call it a day and still have some money left over vs buying a twinpower or splitfires.
this info in this thread is excelent, even just for the spark plug numbers, its much appreciated!
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1660615
The splitfires are good for stock replacements, they are much much cheaper. I end up paying over $100 for a single new coil from Yahoo japan through Rinkya.
If your coils are truely going bad, they obviously will make a difference. My point is it not a good idea buying a DLI and sending that power through dying coils.
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1661875
agreed.
i plan on wiring up these external coils and seeing how she goes, but i do agree that trying to power up dying coils is a bit stupid.
if all goes well these external coils should help a bit and if not its not too much lost (1$ for 3 NIB coils off ebay) and i can always go with the proven splitfires......
https://www.sau.com.au/forums/topic/91876-cooler-plugs/#findComment-1661887
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
