Had my PFC tuned yesterday by CRD in Sydney and am very happy with the job they did and the end results. made 194RWKW.
My current mods are,
Pod filter
Full 3 inch exhaust and hi flow cat
boost set to about 13psi
Hybrid FMIC
Ex cam gear
PFC
Now, what to do to break 200 mark???
https://www.sau.com.au/forums/topic/91913-pfc-tune/
  • Replies 47
Posted Images
Use photoshop :(
Seriously dude i wouldn't worry about the figure, 6rwkw won't make that much difference. If your happy with how the car drives/pulls then be happy, don't worry about numbers.
If you want more power, time for a new turbo, something like a HKS 2535.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1657379
do u have a graph with AFR's?
what are they like?
are you planning on running 13psi all the time?
I was not given the AFR chart, I should call them, do u think they will have them saved in a database?
I may drop the boost back to 11-12psi just to be safe.
I also had compression test done all cylinders were 165-170psi. not too bad at all.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1657567
Yeah, most tuners save it and can simply recall it in a matter of seconds
I'd be dropping the boost back a couple psi :(
Ceramic wheels are your enemy
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1657593
good figure, how does it drive on the street? thats all that matters really
the 194rwkw powerfc will drive heaps better than the 201rwkw safc tune
looks like boost tapers off a little, what dump / front pipe combo do you have? all in all looks good.
are you happy with how it runs? now its time to see how the fuel economy is :(
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1657848
CRD pointed out the boost drop off and believe the wastegate spring may be worn and leaking pressure a bit. Not too concerned about this atm.
I just have the 3 inch dump pipe from flyn, not the split dump with seperate exhaust for the wastegate.
Drives very well, in second gear giving it a bootfull from just putting along it will break traction anywhere from 60 to 80kph easily now, although off boost there is no difference (that i can notice). To be honest i was expecting a bit of a power gain while just under normal acceleration.
Anyone know if you should get power gains under light load?
I will see how economy goes in a few weeks, at the moment i am enjoying the acceleration too much.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1658005
Already have, i am getting bad spiking from my boost controller causing massive amounts of knock. The spiking did not show up on the dyno cause they start the acceleration before the turbo has spooled up giving the bleed valve more time to adjust to the pressure changes.
The spiking is only happeneing when i put my foot down when the turbo is spooled up, so anywhere above 3000rpm.
I have dropped it back to 10 for now. sure can notice the drop in power. Knock is good now, cant make it go over 25, before i had a spike of 127 on the knock scale. Very bad i think.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1658039
I agree..
Post up the AFR graph when you get it, im interested to see how they are :P
And with the boost, i would not expect the stock turbo to hold 13psi all the way to the redline, just as the graph shows.
Also with the lack of extra acceleration off boost, they probably did a full throttle tune, with not much work on the rest of the map, were u there when they tuned it?
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1658948
The problem with having it tuned for say 13-14psi is that if you drop it back to 11-12psi chances are the tune is not going to be optimal as the tune isn't suited to that boost level.
If the tuner has done his job properly that shouldn't be the case. Boost is irrelevant, he is tuning to airflow as the primary load source, with rpm as the secondaary reference. Turn the boost down and the airflow decreases at the same rpm, which should be reflected in the mapping (ie; the load points used). If the tuner has mapped the load points correctly then no problems, power is maximised.
:P cheers :(
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1659015
:P cheers :(
I figured this is how it would work SK. Cheers for the clarification.
I am getting the AFR chart today, will post up then.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1659029
Is this just the stock turbo simply running out of puff?
Does anyone else have a similar drop in pressure at high rpm with stock turbo?
The car was on the dyno from 5pm till just after 9, so 4 hours. I was there for about 4 runs on the dyno from about 7.30.
https://www.sau.com.au/forums/topic/91913-pfc-tune/#findComment-1659034
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
