Pfc Tune
Damo
 Share
Had my PFC tuned yesterday by CRD in Sydney and am very happy with the job they did and the end results. made 194RWKW.
My current mods are,
Pod filter
Full 3 inch exhaust and hi flow cat
boost set to about 13psi
Hybrid FMIC
Ex cam gear
PFC
Now, what to do to break 200 mark???
  • Replies 47
Posted Images
Use photoshop :(
Seriously dude i wouldn't worry about the figure, 6rwkw won't make that much difference. If your happy with how the car drives/pulls then be happy, don't worry about numbers.
If you want more power, time for a new turbo, something like a HKS 2535.
do u have a graph with AFR's?
what are they like?
are you planning on running 13psi all the time?
I was not given the AFR chart, I should call them, do u think they will have them saved in a database?
I may drop the boost back to 11-12psi just to be safe.
I also had compression test done all cylinders were 165-170psi. not too bad at all.
Yeah, most tuners save it and can simply recall it in a matter of seconds
I'd be dropping the boost back a couple psi :(
Ceramic wheels are your enemy
good figure, how does it drive on the street? thats all that matters really
the 194rwkw powerfc will drive heaps better than the 201rwkw safc tune
looks like boost tapers off a little, what dump / front pipe combo do you have? all in all looks good.
are you happy with how it runs? now its time to see how the fuel economy is :(
CRD pointed out the boost drop off and believe the wastegate spring may be worn and leaking pressure a bit. Not too concerned about this atm.
I just have the 3 inch dump pipe from flyn, not the split dump with seperate exhaust for the wastegate.
Drives very well, in second gear giving it a bootfull from just putting along it will break traction anywhere from 60 to 80kph easily now, although off boost there is no difference (that i can notice). To be honest i was expecting a bit of a power gain while just under normal acceleration.
Anyone know if you should get power gains under light load?
I will see how economy goes in a few weeks, at the moment i am enjoying the acceleration too much.
Already have, i am getting bad spiking from my boost controller causing massive amounts of knock. The spiking did not show up on the dyno cause they start the acceleration before the turbo has spooled up giving the bleed valve more time to adjust to the pressure changes.
The spiking is only happeneing when i put my foot down when the turbo is spooled up, so anywhere above 3000rpm.
I have dropped it back to 10 for now. sure can notice the drop in power. Knock is good now, cant make it go over 25, before i had a spike of 127 on the knock scale. Very bad i think.
The problem with having it tuned for say 13-14psi is that if you drop it back to 11-12psi chances are the tune is not going to be optimal as the tune isn't suited to that boost level.
Edited by Cubes
I agree..
Post up the AFR graph when you get it, im interested to see how they are :P
And with the boost, i would not expect the stock turbo to hold 13psi all the way to the redline, just as the graph shows.
Also with the lack of extra acceleration off boost, they probably did a full throttle tune, with not much work on the rest of the map, were u there when they tuned it?
If the tuner has done his job properly that shouldn't be the case. Boost is irrelevant, he is tuning to airflow as the primary load source, with rpm as the secondaary reference. Turn the boost down and the airflow decreases at the same rpm, which should be reflected in the mapping (ie; the load points used). If the tuner has mapped the load points correctly then no problems, power is maximised.
:P cheers :(
:P cheers :(
I figured this is how it would work SK. Cheers for the clarification.
I am getting the AFR chart today, will post up then.
Is this just the stock turbo simply running out of puff?
Does anyone else have a similar drop in pressure at high rpm with stock turbo?
The car was on the dyno from 5pm till just after 9, so 4 hours. I was there for about 4 runs on the dyno from about 7.30.
 Share
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
