if i use these struts in the hr30 do i have the use the r31 insert or will the r30 insert fit?
i'm getting a set for my r31 gxe, but wanted to put them in my hr30 for compliance cause i have to take out the coilovers, i can still use the r32 calipars and rotors on the import r31 struts...
Edited by rsx84
https://www.sau.com.au/forums/topic/91960-hr31-struts-in-a-hr30/
From memory, the R31 struts are shorter than the R30 inserts. You will need to use the R31 strut and insert complete (and if you are doing it for compliance / rego purposes only, why would you care).
Oh, and when you find a second set, just shoot me a PM please... :D
Cheers,
Matt
The Australian built R31 struts are different to Japanese built ones. The inserts are different between both.
Most import sedans and coupes have the same struts and inserts, though I have heard that some of the R31 imports (RB20E/RB20ET models) have a strut more like the Australian models that have a non floating hub, which severly limits your brake upgrade options.
So I guess go with a set from anything RB20DE/RB20DET powered and you'll be right
i've got the konis book here and they class the sedan and coupe as the same insert??
Yeah,they are different though! Spacers under Aussie inserts is rather dodgey too,as the top of the Jap inserts are different shape to Aussie ones as well! And the import struts have a solid top hat with a proper ball bearing race,as opposed to sloppy rubber ones for the local model.
ok the question is. you say they are 1" shorter in shock length, would this also mean the total lenth of the strut is shorter?, can the R31 fronts be bolted in onto a hr30 ?
If im thinking right, that would lower it 1"
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
