if i use these struts in the hr30 do i have the use the r31 insert or will the r30 insert fit?
i'm getting a set for my r31 gxe, but wanted to put them in my hr30 for compliance cause i have to take out the coilovers, i can still use the r32 calipars and rotors on the import r31 struts...
Edited by rsx84
https://www.sau.com.au/forums/topic/91960-hr31-struts-in-a-hr30/
From memory, the R31 struts are shorter than the R30 inserts. You will need to use the R31 strut and insert complete (and if you are doing it for compliance / rego purposes only, why would you care).
Oh, and when you find a second set, just shoot me a PM please... :D
Cheers,
Matt
The Australian built R31 struts are different to Japanese built ones. The inserts are different between both.
Most import sedans and coupes have the same struts and inserts, though I have heard that some of the R31 imports (RB20E/RB20ET models) have a strut more like the Australian models that have a non floating hub, which severly limits your brake upgrade options.
So I guess go with a set from anything RB20DE/RB20DET powered and you'll be right
i've got the konis book here and they class the sedan and coupe as the same insert??
Yeah,they are different though! Spacers under Aussie inserts is rather dodgey too,as the top of the Jap inserts are different shape to Aussie ones as well! And the import struts have a solid top hat with a proper ball bearing race,as opposed to sloppy rubber ones for the local model.
ok the question is. you say they are 1" shorter in shock length, would this also mean the total lenth of the strut is shorter?, can the R31 fronts be bolted in onto a hr30 ?
If im thinking right, that would lower it 1"
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
