Thanks Cubes, my car had been having a reall bastard of a problem since the rebuild and we couldn't sort it out - tried all the spark problem reasons (plugs, coilpacks, ignitors, earths, ecu etc etc), turned out to be a problem in the fuel pump wiring.
Working fine now with the setup in this thread :sick: we have a lovely 14.2 - 13.8v at the pump now :laugh:
Just a standard pump for me....I assume the problem is in the old wiring, computer or relay somewhere.....but the rewire was simpler than workign through it, with the bonus of a higher voltage at the pump as well :D
  • 1 month later...
Hey guys I have an R34 and currently its got an amp installed with 0 guage wiring. Along that 0 guage I have one of those Stinger 3-Way splitting block thingies (can't remember the actual name), can I just run an 8 guage from that split to the relay/fuel pump without putting a fuse on the new 8-gauge line? Would the fuse on the 0 guage to the amp be sufficient?
And this all done to the wiring loom that comes out of the metal lid that sits on top of where the fuel pump is located right?
Edited by Andi
Doubtful, if your running 0 gauge to your amp it's probably got a fairly hefty fuse on it. Internal fuel pump only needs a 15 and an external one maybe 30. I went to jaycar and bought relays with a blade fuse built in, makes it much more easier and works out cheaper than buying a relay and a fuse holder :thumbsup:
I did mine right to just before the plug, ie. took the lid and the plug of and cut it just before the plug, thinking about it it does seem like a bit of a waste to use 8gauge to the internal pump, the wire from the plug to the pump is only gonna be the pissy standard wire neway....still looks good though I suppose :)
  • 4 weeks later...
The R32's do have variable speed pump control.
As soon as you touch the accelerator the pump receives the full voltage.
However, the AP Engineering PFC bypasses the variable speed control. The PFC has the pump running at full speed all the time.
I had tested the fuel pump voltage at idle, stationary with rev's and under load on boost. Voltage hardly varied, 11.2v being the peak.
I did the same test on my 32 gtr and got 11.2 peak on the positive BUT its the negative side that is varied above earth to control the pump voltage so to get a true reading you must test across the pump terminals and not from the positive terminal to earth.
with the gtr modulator the minimum negative voltage is 2 volts above earth. So if you put adirect feed the pump positive the highest pump voltage will be 13.8 - 2 so 11.6 volts at the terminals.
well, I'll assume instantly that the Nismo and Tomei pumps will take 6 months to get and are about 5 times the price.
Are the Bosch pumps really that noisey?
Even the intank 040's ?
hey fella
Grab a 044 and head down to pirtek.they will supply you with all the fittings and non return valve to mount the 044 intank.
grab a filter sock from a v8 falcon from your local parts supplier and your away..
simple common sense mod but with more flow then the 040 and wisper quiet.
i have pics if your interested.
Darren
does grounding the neg wire on the fuel pump do the same as this mod ?
or is the main idea that your changing to better quality wire ??
btw i got a 040... shes quiet as can be.. you wouldnt know its there. Alltho when ur down to like 1/4 tank you can hear it chugging away sometimes.
I think I follow what you are saying...
I did my testing across the pump terminals. By earthing the multimeter to chassis it picked up 0.5v.
Also.. the GTR and GTST's use a different modulation setup, not sure on the specifics but the GTR ecu has 2 outputs high/low where as the GTST has one.
  • 2 months later...
Can I just use the item here to do this guys? Will save me having to buy a fuse holder and fuse. 30amp should be enough for a single pump right?
http://www.jaycar.com.au/productView.asp?I...=&SUBCATID=
Also, am I suppose to be dong this UNDER the lid, or ontop of the lid? My car is an R34 GTT and when I had a look again today theres a metal lid with a plug there that has about 4-6 wires. How am I suppose to run the 8-guage power and earth through the lid if its solidly sealed?
Thanks,
Andy
I'm not familiar with the 34 GTT lid, on the 32 there is a rubber grommet that 5 wires run though, I just ran the additional wire through the grommet. You could just tap into the standard wiring if you need to but its not ideal
Looking at this diagram, after the fuel pump relay there is something labelled an 'air regulator'.. what is it?
Also the wiring colours that cerbera quoted in the first page are totally diferent to what I seem to have. I went through the hassle of pulling the pump to double check as what I was measuring didn't correlate at all. My pump is White/purple for +, Blue/red -, and yellow and yellow/blue for the gauge set. Anyone have similar?
james.
Here is a wiring diagram for the RB20DET. It clearly shows the fuel pump setup.
Not really sure; from what I can see its pretty straight forward whats going on.
When the FPCM receives the signal from the ECU the the voltage earths directly.
When the FPCM doesn't receive the signal from the ecu the earth passes through the dropping resistor.
The GTR is essentially identical apart from the FPCM containing the dropping resistor and receiving 2 signals from the ecu to determine if the fuel pump is high or low.
In the R33 on the rear shelf is a fuel pump box that regulates the current for the fuel pump no one seems to mention that? Have people just removed this ?
On a 95, R33 should i need to re-wire the whole pump or just replace the battery earth and possibly fit an engine bay earthing kit?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
