lets be honest, a 12sec car is enough of a handful on the street( not to mention 11, 10, 9 sec) without testing your brakes every few seconds. i always try to stay out of first, when i see the lights turn red down the road, back 2 gears and roll. mate of mine ran into a cow on a blind corner on his ducati middle of nowhere. bad outcome, you just never know.
If i wanted to drag at lights i would have bought a fully sicked out commo or falcon mate, But hows about F%@K that!
So you have NEVER done that? I bet your talking shit if you say you havent...
Truth be told most of you guys talk about being soo nice on the roads on the forums but are opposite when your behind the wheel. I know its not all of you but its fair to say most. Why buy a skyline for if your going to drive it like a grandpa? I dont speed, i just like to get the limit quicky, anyhting wrong with that? Even if someone wants to go me at the lights, ill give them a go, but i stop at the speed limit. I too have never gotten a speeding ticket yet *touch wood*
Totally agree with you.
I'm not going to lie.
I wouldn't say I thrash cars for no reason, its either to get up to the limit quickly, or for that occasional bit of fun. I sometimes enjoy a bit of fun at the lights and go past the speed limit etc. I often speed, but nothing ridiculous.
I've had my Ps for 2 years now, 1 speeding fine. So not too bad.
I'm surprised at the number of do-gooders on this site I mean, i can understand not racing, but speeding, everybody speeds, even if its just occasional.
But if you really don't speed/drag, good on you. Credit where credits due.
Well said. Agree 100% :(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
