Skyline King has made a tentative offer to organise a Dyno Day
Probably on the Gold Coast.
I know from expearience with these forums that a lot of people will probably express interest. What i'd like to know, and probably Skyline King too, is how many would actually turn up for it on the day.
For starters.....I am interested.....and I WILL turn up on the day
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/
  • Replies 76
Guest Skyline King
thanks for that jay51...
I can run a dyno day any time that suits all of us.I have alot cars in my shop at the moment so i need to organise some room...
i need to know :-
do you guys want JUST skylines or can we invite anyone
would you guys like to see BIG HP cars
if the price was $50 a car is that not too much
if $50 is ok then lets make up classes for trophies like
4CYL stock "factory form"
4CYL modified "light mods"
4CYL pro "heavy mods"
6CYL stock
6CYL modified
6CYL pro
8CYL stock
8CYL mod..
8CYL pro
any suggestions ???????
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/#findComment-21195
Hi Dude, I organised a dyno day a short while back and it went pretty well. Here are the categories I used.
4 cyl upto 2l
4 cyl 2l and up
6 cyl 2l
6 cyl 2l and up
Rotory
Eight
I imagine you will get more cars than I did because of your location (I am in Toowoomba) so more categories may be needed.
Please don't take this as critisism but there are a couple of things wrong with your categories.
1. "STOCK" - How can you be sure the car IS stock, some cars will have mods that can't be seen.
2. "Light Mods" - What is considered Light mods? You will have many problems with people who say that sos and so hs more mods and so and so has less mods, you don't need the hassle of people arguing about who should be in what category.
3. "Heavy Mods" - Again, how can you determine who has what, some people will say I have x x x x mods then when they turn up they have more or less than they said so it will screw up your planning...
Basically as the organiser you don't need the hassle on the day as you will have heaps to do as it is.
The categories I would suggest for your even would be.
4 cyl upto 2l Turbo (Starlets. CA Silvia's etc)
4 cyl 2l and up Turbo (SR Silvia's, TX3's etc)
4 cyl 2l and up N/A
6 cyl 2l Turbo (RB20 Skylines)
6 cyl above 2l Turbo (GTR, Supra etc)
6 cyl above 2l N/A
Rotary Turbo
Rotary N/A
Eight
Automatic (You need a different category for Auto's as they can't be dyno'd in the same gear as the others)
Sounds good and I can't wait. Will you be using shoot out software? We used this to keep in line with Summernats etc so people know that they have been dynoed all with the same settings per category.
Just trying to help, if you want to know more about our day just ask.
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/#findComment-21246
well i dont think it should be open to just anyone.. only by special invite by sau members. If we are going to have club events, we have to make them more exclusive so it is actually worth being a member.
on another note, skyline king - do you sell different lengths of pre cut and bent pipes and silicon joins?
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/#findComment-21311
Guest Boxhead
i agree with pete smith on the exclusive thing...
it should only be a SAU members day... however i think that it shouldnt matter which of there own cars the bring... as long as yoru a member.. $50 i am there for that price...
just put a date down.. but not sunday... any other day but sundya ok
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/#findComment-21373
Guest Boxhead
oh and im curious on why are we having little comps???
like i thought the idea of a dyno is just to see how your car has improved, what level it is.. sort of like a 1/4 mile on the track, your only racing the clock( or dyno in this case)
soryr guys, i dont want comps coz i know myn will loose,
nismo girl, my car will beat yours to slowest skyline...
since i have a n/a rb20...
https://www.sau.com.au/forums/topic/921-queensland-dyno-day/#findComment-21375
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
