13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Despite reading this thread, and seeing the excellent results rev has had, I'm still not convinced that the traditional mods aren't the way to go. I think you're just really good at drag racing, rev. That said, it's certainly made me interested in the lightened flywheel. If I was in Perth, it would be good to see what times you could get in my car.
Guest MFX_R33
Jay that just alters the gearing. In some cases that may be quicker and others it would be slower. I know Mario's GTR's gearing, for example, has a very high first gear (I believe it is close to the same ratio as a standard 2nd). Also smaller tyres may make you need one more gearchange before the line which will slow you down.
Jeff.
Jeff,
I understand what your saying, it can make you slower if they are excessivly smaller. But, for say 10% smaller, it'll make a difference without any side effects (other than your speedo being out :) ).
You've got to remember that Mario's beast of a car has been made for the strip, rev's to 10,000, has 1000hp, and he launches at about 8,000rpm and almost every part on the car has been changed for an after market modified part - lucky ba$tard :D .
So in his car there's no use having a standard first gear. He's car also would reach it's absolute maximum speed just after he passes the finish line.
Just as an example, if you take a R33 GTS-t with standard gearbox and stock final ratio, and run it down the 1/4 mile and say you hit 100mph at the end, you'd need to be in 4th gear to make it too 100mph. But if you change your final ratio by 10%, which makes you accelerate faster and you pass the finish line doing 110mph you'd still be in 4th gear, so your not doing any more gear changes than normal, your just accelerating faster.
The absolute top speed of the car will be less, but when most are still limited too 180km/h, I don't think that's an issue :spank:
That's a basic way of looking at it though.
I remember in my old car when I changed from 50 series tyres to 55 in the same size (205's I think), and when I picked it up I thought they had stuffed the car cause it was noticably slower.
Then when I got home and thought about it, it worked out that they were about 8-9% bigger in diameter, so it made sense (plus the fact it didn't have much power to start with :( ).....
Anyway, this is getting totally off topic here..
Guest MFX_R33
Changing the wheels to smaller, will probably make little difference to the E.T. or MPH of your car. Basically the power of your engine is there to overcome the inertia (constant) of your car down the track. If you are going to the extent of playing with the end ratio of the gearing, you would have to look closely to the potential of the car and calculate getting the longest time in the peak power area of you car. With calculation, you caould find that you could just as easily be better off with larger diameter tyres.
Jeff.
Originally posted by MFX_R33
I agree it will improve your acceleration in each gear, but if just running smaller wheels was going to give you a better ET, every drag car would have 5 inch wheels.
Jeff.
See above post :)
Running 5 inch wheels would be cool, slower, but cool :bahaha:
It's totally different when your talking about a drag car that is made for the strip and that's all.
For a road car that see's the track sometimes, dropping the diameter of your tyres a little will be benefical for acceleration.
Like I said, I've tried it and noticed a difference, give it ago yourself and then you'll see what I'm getting at.
Pass the beer nuts...........
Originally posted by riggaP
Can I ask how people launch their rockets? 7000 and dump the clutch? 7000 and ease the clutch out? 4000 ease clutch out? etc
It totally depends on the quality of the tyres you're using! And the road surface of course.
Poor quality &/or worn tyres will spin even @ very low rpm (~2,000rpm) Even good tyres that have "gone off" will be very hard to launch without excessive w/spin.
It's a case of practice makes perfect! Go for a drive & see how YOUR tyres hold up? If the car bogs increase the rev's until it gets away cleanly.
The above info is dependant on the launch method. I prefer to dump the clutch, but slipping the clutch & feeding power on can help if your tyres are shitty.
To give you an idea - I couldn't launch at anything more than 2,000rpm on 255/40/17 Falken ZE502's but now on the same size RE540S's I can take off @ 3,500+rpm.
  • 4 weeks later...
i ran a 13.872 @99.56 11.1psi
and its fairly stock, jsut electronic boost controler, cat back, stock airbox, stock turbo, street tyres 255s :P, stock engine, minex vx rom ecu, stock clutch.
jsut a matter of interest, i drop my car at 2500rpm then give it 70-80% throttle. then full throttle after that. i find that makes me run 13's. if i give it all hell i rin 14.5s.
my 60footers are 2.189
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
