13.4 second 1/4 for your 'stockish' R33. (A how to guide).
INASNT,
I'll take you up on the offer. You need to find a private road perhaps and play around with the launches to get it right.
I'd give a 2000rpm hill start kind of launch a go because it sounds like most people (myself included) get a little exited and floor the acellerator too early.The accelerator needs to be 'fed'.It's not much of a skill at all, you'll see what I mean when you get it right.
rev: i was trying a couple of times with more restraint but everytime i have done that i have got a slow time. I was launching at about 3000rpm then "gradually" (at least not putting foot to floor after the start) flooring it out to 6500 on 1st.
I have had plenty of practice on err, "private roads" just practicing launches. i guess you need to practice with the helmet on to get it right. With helmet and without helmet are totally different experiences.
For the record.. i have no probs with anybody driving my car for a run to see what it can get and the next meet I take my car. If anyhting, then it might give me motivation to learn better technique myself.
I think on the 'slow times' you may have launched with less revs but, still hit the full throttle too early and instead of spinning the tyres you 'bog down'.
The idea at the strip is to launch like a fast trafic light launch. It's not full throttle till you hit the end of the lights on the otherside.
You can still travel pretty quick with 3/4 throttle.
hi guys,
Over the weekend i did a [email protected] 2.183 60`.I`m running stock turbo-BOV-ECU but i have got a FMIC,boost bleed valve,zorst(turbo back),pod filter,255rears,9-12psi depending on climate.A couple of months ago i had it on the dyno and got 204rwkw(no dips).
rev210- The only reason why i posted this is because i noticed your car is a 1995model and so is mine.Maybe theres something in that?
Matt
REV210 i noticed that you have adjustable timing, i have just purchased a LT-12 microtech for my R33 could you give me an idea on the timing you went for so i have something to go off. Such as total advance at what revs, flattens out to ___ at what revs and how maney degrees retard at what boost, and mayby even what advance at light throtal vacume. Anything would help i think you said 20 deg total so im estimating 30 deg flat from 4000 revs and 10 deg retard due to 10psi of boost. :uh-huh:
This looks great! Exactly what i,ve been looking for. Thanks for your help. Going to go out very soon and try them out. Having a loot of trouble with the idling side of things to, maybe i'm too lean, seams to idle well but when backed of to idle, drops way to low!!
Disregard my ultra rich idle mixtures as I had and air leak that I compensated for. Found out air was being sucked thro my catch can in to the plenum bypassing my air flow meter and butterfly. Clean your AAC valve, its the thing hanging of the back of ur plenum closest to the fire wall. you will see two plugs, the purple one is the right one. This usually solves most idle isues.
mine is connected to the rocker cover aswell- however
there is another smaller pipe with a valve that closes once on boost that comes out of the rocker cover on the plenum side and goes into the plenum. I blocked off the valve with a screw and now I have perfect idle again. My catch can actually works now to, has about 10mm of condensation and oil after a week. Previously had next to nothing. Wouldn't suprise me if other people have made the same mistake.
matt,
I can't adjust my timing per rpm point. I can only set 'base timing' like all stock cars. I have no idea what it really is. A re-graph of timing is a great idea if you have an aftermarket ecu, lots of engine response to be gained.
the 13.44 is a good time. I wish I had 255's like you instead of the 205's, my last run down the 1/4 got me a 13.3 and a wheelspin fest launch of 2.3. I don't know if I'll get down past the 12 barrier with the 205's .
Guest MFX_R33
BOOSTD, that info on the catch can sounds like it is exactly what has been happening to my car. Cause thinking about it now, I have clear hoses throughout the engine bay and the one to the plenum from the rockercover is black, and the catch can hoses have never had a drop on them. I have also had alot of problems with stalling on back off, which were previously written up to the size of the throttle body.
Thanks heaps, as soon a I finish this stage of mod's to my car and eventually get it back on the road I will try that.
:D Jeff.
MFX_R33- Nice one !!! Its always good when you find stuff like that. Guess what.... I got 460km from a tank instead of 370 after fixing the leak. I'm on my second tank full now and have 310 km on the clock and just under 3/4 of a tank left! The car is ten times smoother now around light closed loop throttle aswell. I think because the closed loop operation works so much better without a leak that the car doesn't understand explains my new super economy. Don't forget to remap your light load points.
The valve you've blocked with a screw is the PCV valve (Positive Crankcase Ventilation) Not much point fitting a catch can if the PCV valve is still operating as intended :D Except for looks.
what quarter mile should i get on my car ?
95 r33 gtst with series 2 engine (no ignitor box)
Cold air induction sectioned off in engine bay / k&n filter
supra round core front mount intercooler
hks suppa dragger exaust (3")
VL Turbo T3 high flowed with T4 front wheel running 10psi
standard suspention with 235/40/18
standard computer
apxi twin chamber BOV
Automatic dif (4.3:1 instead of the standard manual 4.1:1) with 5 speed manual installed (i get a few seconds in 4th gear)
If my speed meter read a 13.02 quarter & 4.71 0-100 would that be a fair call to go by ? or would it be wrong ?
are you guys finishing the quarter mile at the end of third ? or just as you clip into 4th ?
Originally posted by MFX_R33
Guilt-toy depends on how well you drive it.
Boostd, my fuel economy also went to shit, although I only get around 250k's out of a tank.
Jeff.
I can drive it goood... would a 12 be possible with those mods?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
