13.4 second 1/4 for your 'stockish' R33. (A how to guide).
yeh it does, thanks J. but I have used a blitz and HKS SQV on my 180SX which is now currently on my 98 rex and had no such probs like they had in terms of low boost and then presing the clutch in so I kinda figured it's got something to do with skyline's?
Cause I have fitted a few bov's to skyline's b4 and a few of them didn't even work! as in won't vent off for some reason.
  • 1 month later...
We made the exhaust in mild steel 3inch and the cooler cut down from a truck ... time was run at kwinana moterplex .. :D
made 278hp on SST dyno in shoot out mode...
Not the first to think its bullshit and wont be the last ..
ah.. Backyard workshops strike again! You just can't beat that kind of value for money. Good work.
although most people won't be able to get away with cheaper than $2k to do the same thing without their very own backyard workshop.
Allo all,
I'm new to the forums and was just bringing myself up to speed when i noticed this jem of a thread.
Now i've recently bought myself a 94 r33 GT-ST (M-spec i beleive but hey new to skylines so i could be wrong) and i've been having a long hard think about what i'm going to do and how i'm going to make it matter by getting as much of that power to the tarmac with mimimum loss of traction, so all of this is of great interest.
So far it seems that the biggest problem with what your all trying to discover (stock BOVs vs 3rd party Atmos V's, LSD and tyre diameter) is that you dont have a baseline. So far everyones comparing their work and results but as we can all see, what works for one lad wont nessecerily work for the next. To me this would be because everyone, to some extent at least, have already got themselves knee deep into their mods so results will vary.
Now i find myself in an intersting situation... My new GT-ST so far is almost as stock as a rock. Besides a K&N pod filter, a 3inch cat back with 4inch tip and an apexi timer (all came with the thing) not a bean has been changed, tuned or tweaked (i even have the original panel filter with cold air box in the boot). So making the right decision first time would be nice.
Now what this leads me to think is "what a great opp to dispell a few myths or incorrect beliefs" not that i have the answers, i dont i have none, but i wouldnt mind finding the definative answers once and for all.
So basically over the next X amount of time my little baby will be getting a course of steroids, and i thought it might be a nice idea if i tested and checked things as i went, hopefully getting us all the info required to find that magic mix of parts (oh and air fuel too).
So people please tell me, what do you wish you'd checked out before starting work? is there anything you would want to try out or do differently if u got your hands on another stock unit (or near to it)?
Maybe as i do my work i can measure this or that and give you figures based on a near to stock unit, or alternatively updates as each bits goes on and is tuned (ie a third party BOV fitted as part of upgrade "A" that gave crap results but came good after adding upgrade "B").
I'll be heading down to Eastern Creek in the near future to set myself an unmodded time, something to compare all the work i do to it against. You never know what the results might turn up.
Ok truth be told i just wanted to say "CRAP WHERE DO I START!!?!?!?!?" but i wanted to make it sounded interesting, involved and full of possibilities. And you never know... doing up a skyline with parts chosen by general consensus might have interesting (or expensive) results.
I hate making mistakes, maybe with all your help i can avoid a few and maybe help others do the same.
Have fun all.
Messiah
Remove the K&N Pod filter and put the standard box back on. Then sell the Pod Filter and buy a K&N "panel filter" to put inside your standard nissan box. This will do 2 main things:
* Keep the cops off your arse for having an exposed Pod Filter
* Get a direct feed of cold air thru the standand snorkel attached to the box.
Hot air = Bad.
Cold air = Good.
So far your cost is $0.
The next thing to do is fit a 3" front/dump pipe and a 3" Cat to your current 3" Cat-back exhaust system. You will instantly notice a difference mid-range and also off-throttle and dyno runs will show you a good 10rwkw extra power over the standard nissan exhaust, it will also raise your boost by around 2psi.
Your now up to ~$750
Next thing would be to get yourself a set of "pineapples" (http://www.skylinesaustralia.com/forums/sh...=before%2Fafter) and this will improve the backend under accelleration.
That bumps you to ~$900.
I'm sure that will cover you for a month or 2, seeya at WSID.
  • 2 months later...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
