Originally posted by meggala
there is a lot of skill required to do it right you should practice in an open area like a car park first so you cant hit any thing.
Meggala,
Do you have suggestions on any car park large enough and empty enough on weekends to safely practice drifting? seems to be quite a time to practice during this wet season...
https://www.sau.com.au/forums/topic/93-why-drift/page/2/#findComment-17882
Originally posted by rs73
Meggala,
please keep discussions of this type (ie the exact location and obvious references to illegal driving) to pm's or emails.
if anyone knows of such a place they can mention that they do and ask that ppl pm them for details.
rs73, i'm not picking on you, it's just we have to be careful of what we say from now on as we have an image to uphold.
thanks
https://www.sau.com.au/forums/topic/93-why-drift/page/2/#findComment-17887
My bro lost his lic this week so now i have a second car Hooray!
Its an 84 corrola and man does it go hard. I never driven a car that was so predictable while drifting in the wet. Proly cause no lsd but its rear wheel drive.
What a great car it uses 5l/100k and i can actually get it in my spot at work(unlike the god dam low as alll hell supra)
So instead of spending 80 bucks a week on fuel to and from and parking now i spend like 10-20 ooooh yeah:) The thing cost $800 and have had it for 18mnths and only replaced 2 tyres at 30 a piece. ECONOMY ECONOMY ECONOMY
https://www.sau.com.au/forums/topic/93-why-drift/page/2/#findComment-19325
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
