I was reading the T04R turbo string and noticed a bit of interest in the T04Z Version .
From HKS the Z version is as follows .
Comp 84mm 63T in .70ARR housing .
Turb 74.2mm 76T in .61/.81/1.00 ARR housing
Claimed power is 700 Hp or PS .
I think SK once said the Garrett GT3540R was good for around the same power so its interesting to note the differences .
The T04Z uses an 84mm 63 trim comp where the GT40 side of the 3540R is 82mm 56 trim . The OD is not much different but the trim jump from 56 to 63 is pretty big and if the aero development is better the pumping efficiency could be as good or better .
The turbine has gone up in size from 68mm (GT35) to 74.2mm but the trim has dropped from 84 to 76 .
Its interesting to note that the wheel diametres make it like a scaled up 2530 and in the same trims too , 63 and 76 . The ratio of turbine to compressor major diametres are very similar as well at 88.3 and 89.6% .
If Garrett have managed to develop highly efficient wheels and kept the innertia down this should be a good thing - I wanna to see the map too !
Cheers A .
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/
Awesome! Cheers for the information, me and some friends have been discussing the T04Z lately. I was just today trying to find out if anyone anywhere had compressor maps for them - partly because the most recent HPI to hit NZ shores (GTR-Special) had an R32 GT-R with twin T04Zs on it.... what a fascinating combination!! :)
In light of what you say about it compared to a GT2530 - it'd be interesting to compare compressor maps, if the "shape" were similar. I had noticed that someone had compared the boost threshold with twin GT2530s...
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1687559
I have done some searching but can't confirm if the wheels and trims are the same for the Garrett and HKS versions . I did follow a link to an E Bay Ad and it shows the cartridge ID tag but light too bright to read the numbers .
HKS have obviously had their comp cover cast up so there may be differences other than the drilled snout air inlet . I'd like to see the cap screws and snout removed though the internal passages are probably not difficult to re create .
None of the pics I've seen show the exhaust housing so I don't know if it's a special as well .
Since the T04R's have been around for a while there must be some exhaust manifolds for the RB26 , would these be only tubular and hi mount ? In a perfect world cast iron and low mount may be more practical if such a turbo could fit down low in a Skylines engine bay .
Lots of pics of Z's and their manifolds please and the ID tag numbers if possible .
Cheers Adrian .
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1690922
Cheers Adrian .
ok heres what a HKS t04z 0.81 housing says on the id tag..
Model: T04Z
OEM P/N: G1 7202-K0001 0
S/N: IF 0227J
P/N: 740759-5002
the hks version has the split exhuast housing to match the split trust manifold too, but im 99% sure the garrett version isnt a split design.
hope it helps
Brad
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1691070
The Garrett T04Z also has the split design. I post up pictures tomorrow morning of the ID tag & the rest of it - It's off the car anyway so its easy.
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1691443
Thanks guys good info . I have seen some pics of a version that may have a 7 blade compressor (well 7 full height and 7 splitter blades you'll know what i mean) so something to avoid .
One of the sites mention a twin entry or split pulsed exhaust housing with a twin integral wastegate set up which could be handy if the turbine inlet pressures are not too high .
StageZilla it would be VERY interesting to see the comp cover with the inlet snout unbolted to let on how they did the anti reversion holes/groove . Actually to see it in its raw glory ie housings removed would make the net zing ! Also has your's got HKS cast into the exhaust housing indicating a non Garrett special ?
Cheers A .
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1691733
HKS had a press release available which showed CAD drawings of the comp cover and its insert. Think of a ported shroud Garrett GT30R cover with an insert over the air gap around the anti-surge ring, and the drilled holes provide air entry/escape to it.
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1691748
Cheers  A .
well i can pull it apart easy enough but how tight do i do the bolts back up? last thing i want is to f**k it up :P
yes mine has the hks cast into the exhuast housing, and 6 blade compressor :)
this one is next to my stock gtr turbo :P
worst thing with this turbo is having to buy the HKS v band flange and clamp for the exhuast which is another $260 from Nengun.
Edited by StageZilla
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1692290
Hi StageZilla , I've only ever used ring/open ended spanniards for turbo housing bolts and never stripped or had any come loose . When brand spankers everything's clean particularly on the turbine side so no persuasuon is needed to remove its housing . Turbos are not short of clamping area so their fasteners don't need to be ridiculously tight especially on the compressor side (aluminium) . Most custom installations need them to be backed off enough to index the housings in relation to the core - the yanks call it clocking .
The greatest danger is dropping the cartridge and bending the blades so this is a pre JD operation and need something soft to lay it on .
Thanks for those pics , the things not as huge as I thought in relation to a standard GTR T28 . A T3 rather than T4 flange on the exhaust housing would have made it more compact again though HKS probably intend it to be an upgrade to to the T04R .
Thanks heaps cheers Adrian .
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1692378
no worries adrian,
also hp ratings are 700hp i think for the 0.81 and 800hp for the largest housing, 1.0
i want response, so thats the reason i chose this over a hks t51R or gt42 garret.
ill have some figures in a few months when the build is finished :(
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1692384
Thank you also WetGTR , any chance of seeing the compressor and turbine wheels side on .
From the cartridge number (740759-5002) both Garrett and HKS should be the same .
Cheers Adrian .
surely the garrett and hks versions are not 100% exactly the same, could be same measurements on the trims etc, but totally different wheel designs or whatever?
and as ive heard from people comparing garrett with hks turbos, is the hks ones will keep on pumping more hp at high boost, where as the garrett stuff runs outta puff at high boost levels and flattens off.
only time will tell :D
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1699110
Same CHRA different housings.
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1699606
Garrett "talk" says same core, turbine and compressor. Very minor changes in the housings to justify the inflated HKS price. No real world differences. That may just be the Garrett line, but I haven't seen anything to doubt it so far.
What are you guys paying for T04Z's? The going rate for the HKS T04Z seems to be around $3K and Garrett is around $2.2K
:D cheers :D
https://www.sau.com.au/forums/topic/93503-hks-t04z-specs/#findComment-1699689
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
