Guys,
Im about to order my T04Z from Garrett and I woud like to know what peoples recommendations for the exhaust housing size are
My engine specs are:
RB26 Head
HKS 272 Step 1 Cams IN and EX
RB30 Bottom End
CR 8.5-8.8
Rev Limit 8000rpm
Cheers Guys.
https://www.sau.com.au/forums/topic/93599-garrett-t04z-which-housing/
Guys,
RB26 Head
RB30 Bottom End
CR 8.5-8.8
Rev Limit 8000rpm
Cheers Guys.
.84 split pulse
.81 single pulse
id go .84
0.81 suits the 26 perfectly so will be abit small on a 3L i reckon....
Hey StageZilla,
What is wrong with the .84 split pulse? Why is the .81 far better?
Just really interested as there have been a few threads about these turbo's in respect to response. R31Nismoid said these turbo's may be able to make the 500rwkw mark; what exhaust housing would you use for this application? And will it loose its 2530 type response?
although i dont remember outwardly saying 500rwkw anywhere  :)
Yea, you did. Quote below.
With fuel and boost 700rwhp i think it would get close too with more boost. I dont think pulp will achieve it... but you never know
It was the post about the TO4Z results.
I used the "SEARCH" button. You must be proud of me! :P
Edited by manage13
Hey StageZilla,
i was only going by the hks t04z's sorry, they only do the 3 housings, 0.64, 0.81, and 1.0 i think, and as r31nismoid said it depends on ya manifold and whether it is split pulse.
cheers
Brad
  • 3 weeks later...
Just to tack on to the end of this thread, does anyone have any experience with the Garrett T04Z with the 0.96 exhaust? I assume power would be very similar to wrxkilla's T04R dyno graph from a few weeks back, and same sort of lag/response?
Talking about a 2.6L too, not a 3L :)
Edited by Amaru
  • 1 year later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
