I remember reading awhile back about the new Camry thats supposed to come out to rival HSV and FPV from Toyota's Aussie performance division. (TRD?)
Supercharged V6 Engine with 180kW or something, 0-100 in sub 7 secs or something and 18" wheels standard.
Anybody got any new info on this thing?
  • Replies 43
Haven't heard a peep from the cardigan carmaker about this thing for ages.
But 180kW and only 6's for 0-100km/hr? That's no HSV / FPV competitor. And Aussie car buyers have proved time and time again that they want their big sports sedans to push, not pull.
I haven't seen any sketches of the new camry, but the new one is to be a 4 cylinder. I own a 96 V6 Camry, 5 speed and it goes pretty well for what it is. There were rumours floating around of them producing a few V6 supercharged camry's, but thet have appeared to back down from this idea.
Instead of a "Lexus" Chaser, Toyota should put the 2JZGTE VVTi in the Lexus IS300 in place of the atmo 2JZ it comes with. That would eat chasers for breakfast. But with the IS and 2JZ so close to the end of their life cycles it is not a viable option unfortunately. But maybe I could do a conversion myself :P
Back on topic, I think making the Camry 4cyl only will help Avalon sales signifficantly, as V6 Toyota buyers will be forced into it, but I think total sales will suffor. The supercharged V6 should give the Avalon a much needed image boost though.
And as for big front wheel drives not handling, I've heard good things about the new Mitsubishi 380, but ultimately it still isn't my cup of tea. If I wanted a $35k+ big car, I'd go second hand, rear wheel drive and German, not new, front wheel drive and Australian. Mid to late 90's BMW 7-series come in at around those $$$ (I strayed off topic again :()
Edited by Big Rizza
They should get rid of those high ass lights that nearly go all the way up to the window, they look shit, they are on every new car except Ford and Holden, and Toyota should make some sexy 4 door pimpin style RWD turbo beast that still looks family driveable but a few years down the track available to the drifters.
Also Mitsubishi should get there asses together and make a RWD magna and then maybe they'd make some sales.
Man i should go sell my parents camry n buy that supercharged one if it ever comes out.. I still dont know why toyota dont make any new sports car.. I mean Mr2 came out, but thats the uggliest thing i have seen.. n its shit..
Or maybe they just done release it here in aus..
Whats toyotas latest sports car?
FWD cars are gay ;3
and no.. if the chaser came here, u'd have to pay a shitload for one..
that's y i was hoping the next GTR wouldnt be released here.. now i bet it'll cost us over $150k and it'll stay that expensive for ages..
gay ;3
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
