i have a complete car as well so their is everything on top of this list...
1 x gearbox manual 5 speed 1500
2 x doors with trims 200 each
2 x sets tail lights 150 pr
1 x boot with s2 wing 250
2 x brake booster 100 each
1 x bonnet cable and latch 50
1 x boot latch with cable 50
1 x rear window 150
1 pair rear drive shafts 100
1 x pair inside rear trims with belts 100 each
1 x rear seat 80
1 x pair front headlights s1 150
1x s1 bonnet imaculate white 200
1 x s1 front bar white 100
1 x full boot trims 100
1 x pair windscreen wipers 50
1 x s2 diff 500
1 x front power steering rack 150
1 x front sway bar 80
1 x s2 computer standard 200
1 x turbo heat shield 50
1 x standard dump pipe 50
1 x standard exhaust manifold 100
4 x standard spare wheeles
1 x windscreen washer bottle 50
1 x pair a pillar trims. 100
1 x standard skyline manual.
1 x airconditioner assembly. 200
1 x fuse box with lid 50
1 x bonnet latch with cable 50
1 x rear bar reo 200
1 x rear bar 100
any queries u can call me on 0421771771
thanks
Edited by campbell
https://www.sau.com.au/forums/topic/93723-r33-parts-for-sale/
  • Replies 41
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
