  • Replies 277
Posted Images
Could anyone who's able to and is attending the cruise, please bring an esky? Preferably people on the southside so I can dump some drinks..
There's only so much room in a skyline that everything will fit into. And without a boot, that's nothing.
I'm now a confirmed attendee, Erin. Andrea and I are good to go. Andrea might have to drive up though as I may still be over the limit due to our Footy Trophy night being held at our house on Saturday night!! Damn the bourbon beast!!
Mud, I'm not sure if we'll be meeting at Crazy Clarks or my house :P
I need quite a few cars to chuck eskies into. I'm going to ask my boss if I can borrow the two tropical ice boxes from work and hope he says yes!
I can swing past your place on my way to C C 's?
or
Transfer some stuff over at Aspley?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
