I've seen it suggested that it's x100 mm Hg, ie 700mm Hg, which is slightly less than 1 bar (760 = 1 bar)
I think that's what on the cluster anywayz.
Makes sense..
I knew it was something like that.
Greg
the gauge is quoted in millimeters of heilium. This is a very old measurement which is pretty much obsolete. A stock HCR32 runs 10PSI of boost, this is what the actuator is set to, and what is displayed when you hook up an aftermarket boost gauge.
No, it's millimeters of MERCURY, 700mm of helium wouldn't be much pressure :D
It comes from when pressure was measured by seeing how much mercury it moved in a measured glass tube. It is also called a 'torr' 1 torr = 1 mm Hg.
Edited by PlasticStan
either way you cut it the stock gauge is usualy wrong 1/2 the time anyways so just get a good aftermarket (not autometer) boost gauge and call it a day.
What's wrong with autometer? Autometer have been around for decades in the US and are made in the US.
I think you mean autogauge?
Greg
Greg
no i meant what i said, auto meter gauges are not as accurate as they tout.
my buddy with a rx7 had a auto meter gauge that said he was only boosting 7-8psi he threw on a greddy gauge (electric) and it showed boost to be more like 12.
just recently a buddy of mine dynoded his s13 hatch with a rb20 in it and the auto meter gauge read 11psi when it was really boosting 15.
from what ive been told the stock boost on a BONE stock gts-t is 7psi, however when the std exhaust has been dropped in favour of a highflowing one boost jumps up to 10psi.
From what you have been told is correct (sought of).
A stock R33GTST runs 7psi - RB25DET.
A stock R32GTST runs 10 psi - RB20DET.
RB20's and RB25's use different turbos, the RB25 (R33) turbo is slightly bigger than an RB20 (R32) turbo - therfore it can make more power at a lower boost level.
My R32 was running 10 PSI on my aftermarket Greddy Guage. After putting in a 3 inch turbo back egzorst it used to spike to 13psi and sit at 12psi all day - this is because the bigger egzorat is more free flowing and can get rid of gasses quicker - im sure on the exact technical term for it but thats what happens when you do egzorst mods to your car i.e: Air filter and egzorst.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
