Datsun 120y coupe with Nissan CA18 turbo motor
Engine & Driveline
GTR injectors / Stock ones as spare
Remapped ECU
S15 T28 Garrett ball bearing turbo
3" dump pipe with full 3" system going under the diff
2x RX7 intercoolers welded together as one intercooler
S13 radiator
Apexi air cleaner
Blow Off Valve
Decompressed headwork with new head studs & OE gasket
Direct Clutch heavy duty organic plate clutch
Std S13 5-speed gearbox
Custom one piece tailshaft
KYB rear oil shocks - Softer for good launches
Mazda B1600 diff with 3.6 ratio & converted to Commodore stud pattern
Datsun 200B front struts with King springs & Monroe shocks
Holden 2001 Monaro front slotted rotors - 300mm & Monaro twin spot calipers
New brake master & clutch master cylinders - R31 Skyline pedal box
R31 Skyline fuel tank 65Litres with std pump
15x4 Commodore pursuit rims - Front
15x7 Commodore pursuit rims - Rear
135x15 Nankang tyres - Front
225x50x15 Toyo RA-1 street slicks - Rear
Body needs work if you want it to draw attention but this car was built to race and it has alot of potential in the right hands.
Selling due to RB20 project and its easier to start another car then remodify this one.
Best time on street tyres is 12.32 @110mph - 1.76 60 foot
Top speed is 245kph - It will go faster if you have the balls
Weight is 850kg
ALO-12 plates not with car - Selling unregistered
https://www.sau.com.au/forums/topic/93932-genuine-12sec-street-car-5000/
As i have been receiving quite a few pm's from people interested or otherwise, I thought i had better clarify a few things.
I am selling car due to a RB20 project. I dont want to spend anymore money on the coupe so i am selling as is. Car can be raced onto a tow truck or raced home with a trade plate. It was registered up until two weeks ago and was defected by DOT about six weeks ago and they inspected the whole car and found this -
Std emission control system not in place - I have a catch can plumbed in
Unleaded fuel restrictor not in place - We no longer have leaded fuel
LG? brake test code not on modplate - Quoted $200 for approval
I know it needs the following for RWC
right ball joint - $20
rear leaf spring bushes - $40
strut bar bushes - $30
interior carpet
right rear diff seal - $40
same size rims all round
The bushes would be optional but recommended - A bit spongy
It would be easy to get 4x std pursuit rims to get rid of front runners etc
With the defect and rego coming at the same time i decided to push the RB20 project forward and start on it. I am open to serious offers on the coupe.
Cheers
Steve
