Knocking noise started yesterday, today i find out i have lost a crankshaft bearing.
Just wondering if you guys think it could be anything else, or if such a thing has happened to you.
also wondering if anyone knows how much this will cost to fix on my 32 gtr.
so pissed, only had the car two weeks too :P
https://www.sau.com.au/forums/topic/93936-engine-repair-costs/
could it be the fuel? jap fuel is awesome, then the cars are brought over here and have to use our "premium" fuel, which is there regular unleaded. going from well over 100 ron to 98 ron cant be good for them.....
just a thought....... :D
also got to remember that most of these engines espcially in the r32's are quite old and have probably had a hard life in japan i would imagine quite a few are just ticking time bombs after 11 - 15 years of abuse... again thats not to say all of them are like this but a good proportion.
leech_ is spot on, alot of the 15 yr old imports are time bombs waiting to go off (I know only 1 person out of 10 now that has bought one and hasnt had any problems... hats off to djhatton!).
You will need to get the crank measured to see if any damage was done and how much. Its an engine out, strip down job so you may as well give the whole thing a freshen up and chuck a set of forged pistons in it (you can pick them up for $1000ish now).
Im with Jayce, Pro Engines in Queanbeyan (www.proengines.com.au). They have done mine and quite a few RB26's and RB25's and all have come out excellent.
$3,500 isn't at all bad for an RB26 if you ask me.
The thing is that you really don't know what the real go is until the engine is sitting in pieces on a workshop floor, so I guess it's not surprising that the cost is going up while the engine is being pulled apart.
You will save about $1500 if you can remove and refit the engine yourself... theyre absolute bastards and waste a lot of time.
Basic freshen up would probably cost around $3000, going for some forged internals and a little bit of head work (which you may as well while its apart) could range anywhere from $4000 - $10,000 depending what parts you use. Ring Pro Engines and ask them.
While the engine is out, you may as well fix the R32 GTR known problems, being the crank drive for the oil pump is too small, so fit a crank collar or get an R33/R34 crank, N1 oil pump, water pump, belts + harmonic balancer. Id be bugeting about $5000 minimum for something thats going to be "safe" at a bare minimum.
Welcome to the wonderful world of the ReBuild26DETT.
How exactly do they measure the crankshaft and see if its scored while its still in the car? Granted it may be possible, but I sure as hell wouldnt trust the results.
You are obviously looking for the cheapest option availible, I on the other hand prefer knowning that the engine has been checked completely and is 100% ok.
Why did the bearing spin? Did it delaminate due to detonation? Was it oil supply problems? If it was oil supply problems, its impossible to check what other damage there may be in the engine due to insufficient oil and/or pressure.
Im a big fan of do it once, do it right... everyone has their own ways though.
EDIT: That may be all well and good for your GTI-R, but I forgot to mention, taking the sump off in the GTR requires a brace holding the engine in the engine bay across the top. Why? Because if it isnt there, the engine will fall out of the car. So yes, either way you go, it is an engine out job.
Edited by Amaru
what crap... engine out for bigend bearings? I just went through the same thing... i did my research before calling people. most people [in canberra] insisted they needed to strip the engine to get to the bearings.. rubbish..
I rang Phillip Head and got their advice.. they said exactly what I read from other forums, and what a heap of mechanics said in syd.. that if its ONLY the bearings they can be replaced by going through the sump, takes a couple of hours. ....
Well while I believe it may be possible to check the bearings with the motor it, it is a huge job and certainly not a couple of hours.
Some of the things you have to remove in a GTR that you don't in other cars include:
whole front subframe
left side drive shaft
left side suspension to remove driveshaft
gearbox
flywheel
front drive shaft
I would suggest they have never had a look at a GTR if they recommend doing it that way :)
Its not impossible but its a bastard of a job.
And then, if a bearing has spun, you will have bearing material all through the the motor, how do you clean it out while in the car?
Alot of these imports die after landing. Its from changing the oil! How? Well the japs don't do oil changes often, which means lots of build up in the oil system. We put fresh oil in them, new oil has detergents which clean the build up off, and next thing you know you have oil related issues.
Dont mess around. Pull the donk out, up end the motor and lift off the sump. You can pull the crank out then and work on it. Look at the bores if they seem fine, just work on the crank and bearings. Why pull the head off if you dont need too? Alloy heads don't like being removed and refitted any more than they need to. It can cause them to crack. This is exactly what I did to mine when I lost oil pressue. Fixed the crank and bearings, threw the sump back on and put it in the car. Relatively cheap really. If you plan on modifying it in the future then you may want to do a full rebuild now. Its your choice. Note, workshops may not cover you with a warranty if they don't do a full rebuild. If your concerned about bearing material through the motor, cut open the oil filter and see how much junk is in there and if it has caused the filter to go to bypass. I would doubt it though. On mine I replaced the oil pump coz it had chips in the gears.
This is my opinion, and incase your wondering yes, I am a qualified mechanic. In a perfect world the motor would be fully rebuilt. Hell why not get a os giken rb30 for it? I try to do repairs that are effective, and give value for money, leaving money for the bits that really make a difference.
Edited by MYRB30
Pro Engines wanted $600+ just to take my engine apart..
$600? no wonder I'm loaded.. :)
Usually it's $200ish to strip and clean an engine, you must have sounded rich or something.. :)
If you're going to keep the car do it once and do it properly if you can afford it, that way you have a solid base for any other mods you want to make in the future.
Edited by proengines
Mate you are deffinatly not alone, at least take that to hart,
dont hate your R because it has let you down, accept it, rebuild it and enjoy it, thats why you bought it.
Common sense would say if you have the engine out which is gunna cost you $1200 - $2500 (it is a certifiable bitch!),
you may as well rebuild the top end also, its pretty old now if its still original internals. You are going to have to accept that its gunna be between $5k and $10K depending on what you do, $5k you should get your bearing, pistons (hone and bore) and labour, thats about it. For a nice build you wont have to worry (too much) about your looking at $8k-10K .
I my self have just been through the same thing. Trust Nick and Pro Engines they know what they are talking about, if you want another place to get a quote from try Queanbyan Motor Builders, they built my engine and I havent had any issues with there work. Dont bother doing it your self, its not a pulsar or a holden.... you dont want anything else going wrong, if it can it will.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
