  • 4 weeks later...
  • 4 months later...
  • 4 months later...
what does everyone think about those ebay DVD units.. i know they will defenitely not be the best but i know if I start spending money on a head unit, Im gonna start wanting to do speakers etcs
im just looking for something cheap, and the ebay dvd ones seem to suffice. especially with Australian maps etc.. for about $400 max..
i didnt really wanna start a thread on it.. but yeh
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6041976
  • 2 months later...
there not to bad, I bought one 2 years ago, and it lasted me about 8 months before the screen no longer folded in and out properly, it would fold out when i started the car, then fold itself back in, or it would get stuck, it ate one of my favourite CD's and it ended up out the window on the hume hwy.
you get what you pay for, i suggest saving your money, these days you can get something decent from a trusted brand, with a warranty for 700+ so I suggest saving your money, especially if you have a nice car for it to go in :)
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6183836
  • 2 months later...
FYI
Just a quick update ipad tablets fit in R34 dash's with mods but same basic dash shape and console area, only the bezel trim and ashtray area needs remolded
They can be perm mount or slide out depending on how custom you want !! Test fit in my car today , plenty of space
And no metal to hit if you slide out on drivers side of lower fash , passenger side has a bracket
so before anyone asks ues you can do it
Cheers
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6298785
  • 6 months later...
  • 1 month later...
FYI
Cheers
FYI
Ipad mini ( 1st gen)
Fits in the dash of a R34 without excess mods or cutting , photos coming of kit fitment in dash
Could fit in just about any newer Nissan
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6682148
  • 1 month later...
Carbon also sells plug in connectors for most Nissan's for the home enthusiast installer!!! You only need a car side plug and the radio side plug like the following:
APP0120.jpg + APP8ALP.jpg = an installed head unit on a R34 :D
Plugs are about $15 each free postage for SAU!!
Some cars need extra parts like antenna adapters for the early Nissans if you have the standard head unit still installed.
Give us a call if you need anything we can try to help out.
Daniel Gardener | Auto Electrical Surgeon
T: (02) 9831 3288 | M: 0411 101 737
E: [email protected] | W: www.carboncarsystems.com.au
Unit 21/47 Third Avenue, Blacktown NSW 2148
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6737140
