got a new bov otherday, and today i wacked it on and was adjusting it, i think it was a bit loose as the idle was up and down a fair bit, anyways i took it for a spin and getting up the street it became really bad didnt really wana drive juste idle serge, only traveled 200m odd, anyways i limped it home, and tighteded it up and got it idleing normal, but i have noticed its blowing a little black smoke, as i tightened it up more, the smoke got less and less, now i DID do a search on it and i found black smoke usualy means running rich, and my car runs slightly rich but can my bov's spring tension effect how rich it can run??? im a little worried to drive it now, no performance loss or anything, all idles the same now just a slight haunt of black smoke now, any ideas?
and yes i will put original bov back on tomorro
cheers guys
https://www.sau.com.au/forums/topic/94085-black-smoke/
atmo mate, and unless i have it that tight taht it wont vent proply and get flutter, when it was idling like a pig it vented awsome, but its that tight now i get reversion, my old bov was the same and was tuned with reversion and really tight , but it shouldnt really matter should it
https://www.sau.com.au/forums/topic/94085-black-smoke/#findComment-1699282
Unless it's open the whole time in which case it'll do what you're saying.
Turn you engine on, open the hood and look at the bov.
Pull lightly on the accellorator cable to rev the engine and see if the bov is opening. Don't rev too hard only a little. If it's opening it's too loose.
https://www.sau.com.au/forums/topic/94085-black-smoke/#findComment-1700378
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
